Lathe Machine From China...HELP! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 09:34 AM   #1
lathe machine from china...HELP!
Hi Guys.
Hoping for you help here, story is:
I bough a industial machine (a lathe) from China, now this machine has a 380v motor but running at 50hz , 950rpm, single phase 2.2kw.
Does anyone know how to get this working? I'm looking for a 380v 60hz 950rpm motor now but i'm guessing i'd need a step up transformer from the 110v > 380v . correct?
or can i put in a 220v motor, as they seem more available than the 380's?
any help apprechiated.
Regards
J. O.
jackoneill is offline   Reply With Quote
Old 04-14-2009, 09:49 AM   #2
joed's Avatar
Rewards Points: 12,850
Are there any other components on the lathe that use the 380 volts if not then look for a 3 HP 240 volt 60 Hz motor and then you won't need to do any converting. Are you in North America? We use 60 hz here.
Old 04-14-2009, 09:53 AM   #3
Rewards Points: 2,350
Jack, General Hammond would want you to send it back and buy an American made machine. or at least a machine made in an English speaking country...
But the only way to get this thing to work is either a transformer, or new motor. Is it single phase or 3-phase? A new motor is probably cheaper than a transformer.
Old 04-14-2009, 10:07 AM   #4
Got those hz round the wrong way, sorry yes i'm in the US, machines original motor is 50hz.
a SG-1 fan Inphase277? I've heard all the jokes about my name!
its single phase.
Then do you guys know where i can get a similar motor but at 60hz?
I'd still need a step-up xformer though if i did get a 220/240v motor (from the 110v standard power supply)?
J.O.
Old 04-14-2009, 11:53 AM   #5
Rewards Points: 156
You can easily correct this issue with an inexpensive VFD. Your motor is 3 Hp. You will need to buy a 460 volt 3 HP VFD. Then you can set the max output voltage parameter to 380 volts and also set it to match speed (950 Max) and Hz (50) too.
You will get an extra advantage with a VFD as you can adjust the speed. You can set your pulley arrangement to the fastest setting, then use your VFD control knob to increase or decrease speed, provided you have enough torque. You can play with the pulley arrangement until you find the best one.
The VFD is only for the motor. The controls may need a transformer.
Check www.automationdirect.com (best price)
www.baldor.com (good price/ easiest to program)
www.tecowestinghouse.com (great price)
www.wegelectric.com (great price)
Search for Variable Frequency Drives (VFD). Will cost approximately $500.00 + or - a few bucks.
Old 04-14-2009, 12:36 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
For the the US you already have 240V 60HZ
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-14-2009, 01:36 PM   #7
joed's Avatar
The biggest problem is the 950 RPM. There are lots of 3HP motors around but non of them have that RPM rating that I have seen. I don't think I have ever seen a motor with that RPM. 1725 or 3600 are the common RPM values.
Here are some sites.
http://www.baldor.com/products/ac_motors.asp
http://www.galco.com/scripts/cgiip.e...at/catalog.htm
Old 04-14-2009, 02:00 PM   #8
Rewards Points: 156
Thats why the VFD would solve his problems. I am looking at a 3Hp motor in a Weg Electric motor catalog and they offer 900 RPM. But you are right. They are not common. Motors are not rated in absolute speed due to slip. Standard speeds and poles listed are below.
3600 RPM = 2 pole
1800 RPM = 4 pole
1200 RPM = 6 pole
900 RPM = 8 pole
So a 1750 or a 1725, RPM motor would still be a 4 pole motor. Or nominal 1800. 950 RPM will be a 8 pole motor. So the OP would use a 900 RPM, 8 pole motor to replace the motor he has. Unless the motor is proprietary and was built special for the lathe manufacturer. Even special motors rarely deviate on number of poles.
Professional motor people never use the words 1750 RPM. They use 1800 to eliminate confusion.
Old 04-14-2009, 08:30 PM   #9
yes an inverter will drive your 3PH motor using single phase supply. I have a Chinese lathe. Rapids coolant and main motor are 380 V, 3 phase. Light 32v. Controls are low volts, not sure what though without looking. In mine reverse changes clutches in the head electrically BUT a different speed range happens with reversing the main motor which also changes the clutches in the headstock. If your control levers are electric you should either get advice or send it back as you will run into further trouble unless you install 3 phase supply
lemuzz is offline   Reply With Quote
Old 04-14-2009, 10:45 PM   #10
Idiot Emeritus
Rewards Points: 1,492
In the original post, the motor is single phase. As you know, a VFD will not operate a single phase motor.
If it were me, I's use a transformer to boost the voltage. It'd need to be 240 volt primary, and 120 volt secondary. 0.75 KVA would be the minimum, I'd use a 1 KVA. Simply hook it up as an autotransformer, and boost the 240 up to 360. That would be close enough to 380.
This way would be considerably less expensive than a 240 to 380 volt transformer.
The original motor is 50 HZ. If this motor is operated on 60 HZ, it'll produce about the same HP, but run a bit faster. Since this motor runs at 950 RPM on 50 HZ, it is a 6 pole model. It'll run at about 1150 RPM on 60 HZ.
Rob
P.S. The motors on this type of equipment are usually metric frames. Very hard to find replacements. Sometimes, a standard NEMA frame motor can be made to fit, usually mounting holes will need to be drilled, and the belt pulley will need to be replaced as well. If it's direct-drive, it's extremely difficult to adapt to a NEMA frame.
micromind is offline   Reply With Quote
Old 04-15-2009, 01:38 AM   #11
Rob
OOps I didn't read it was single phase. Yes mine is metric frame. Just had a look at the electrical diagram. The forward / reverse clutches are 50volt All motors are 380volt 3 phase . Can't find voltage for control switches. Light is 32volt I dont know whether his has similar switching, but if the spindle control is electrical rather than mechanical most probably similar to mine
Old 04-15-2009, 09:42 AM   #12
Rewards Points: 156
Rob, I did not notice the single phase either. Just 380 volt. Never seen or heard of a single phase 380 volt motor, or a 460 volt single phase motor. ......John
Rob
True metric frames are widely available in the US today. Weg Electric and Lafert USA, are two of many more that stock in the US. My local motor shop has over $300.000 of metric motors on the shelf. We have alot of foreign machinery and facilities around this area. SC.
Old 04-17-2009, 05:45 AM   #13
Thanks very much guys.
Now, i looked into this and its a 3 ph. motor 380v 50hz ok.
Our line is a single phase, was thinking and please chime in if im work and i probably will be :
1. get a phase converter, single ph > 3ph (115v ea line? 240v?)
http://www.phaseconverter.com/#Rotary TEMRS6000-3KW
2. transformers on each of the outputs from the phase converter to up it to 380v
3. connect a vfd from the transformers to change the hz to 60.
(long winded or what!)
from their online manuals of the vfd (460V Class - Three Phase) i noticed you cant change the voltage?
i.e input 115 / 240 > 380
I'm probably way off.
Thanks again
J. O.
Old 04-17-2009, 10:24 AM   #14
Rewards Points: 156
VFD's will accept a single phase input and output three phase. At 3Hp, no derating required. Now, you can rock and roll. Much cheaper than a phase converter and no moving parts.
Old 04-17-2009, 01:24 PM   #15
thanks but i'd still need a transformer to up the power to 380v from the vfd?
-- power into vfd (single phase) to
-- output to 3 phase 50hz to
-- step up transformers to
-- the 3 ph. motor 380v 50hz
something like this:
http://www.variablefrequencydrives.n...90010TDN4Z.htm
thanks
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 06:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
