Large Junction Box Before Transfer Switch - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 10:48 PM   #31
Rewards Points: 379
Originally Posted by k_buz View Post
Incorrect. That is for plastic device boxes. They do make plastic snap in romex connectors.
As for the wood mounting, I think that would fail as well. There is no specific code, but I'd be willing to bet the approved method to mount the terminal blocks are on a metal rail that would mounted to the box with screws. Maybe they make a plastic rail for this application so you don't have to bond the mounting rail.
OK, I'll use the plastic snap in romex connectors. I see the safety issue there.
The terminal blocks are mounted to a metal rail that is bonded to the ground bar. I used the wood blocks to provide stability. I have other non-combustible material to use in the place of wood. Simple fix, but I'd still like to see a code reference to prohibit the wood blocks.
DanS26 is offline   Reply With Quote
Old 12-30-2012, 11:05 PM   #32
Rewards Points: 379
If it is more than two feet, you haven't derated the wires. Those #12's are now rated at 10A (assuming 20 conductors in the raceway).
I have not permanently mounted the box yet, but I'll make sure it less than two feet. Thanks for the heads up.
Old 12-31-2012, 12:15 AM   #33
Special User
Rewards Points: 1,230
Originally Posted by DanS26 View Post
I'm willing to remove the wood, but give me a code reference.
No idea, that's why I asked the question.
Most things electrical need to be UL-listed though. I'm guessing the wood isn't listed.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Generator Manual Transfer Switch BJohnston Electrical 1 11-06-2012 04:33 PM
Bypassing transfer switch in RV to backfeed panel chadmw7 Electrical 5 07-28-2012 04:06 PM
Installing a Reliance 31406CRK transfer switch LeeB18509 Electrical 2 03-17-2012 02:22 PM
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
