06-30-2012, 09:16 AM
#1
Laptop cooler voltage question
Hey, so i am making a cooler for my laptop, and i have 3 12V fans that i am going to run to a single phone charger and plug into the wall. i was just wondering if the charger can handle that many volts, it says 5V on it. Thanks
06-30-2012, 09:24 AM
#2
If you wire them in parallel you need a charger that provides 12V. If you wire them in series you need a charger that provides 36V. I'd suggest swinging by your local thrift stores. You can probably find a used 12V wall wart for a couple of bucks.
The Following User Says Thank You to a_lost_shadow For This Useful Post:
06-30-2012, 09:46 AM
#3
The charger need two thing to be correct. The voltage and the watts. The charge will need to be 12 volts. It also needs to be enough watts or current for the fans. Look on the fans for a current or watts rating and add them up. The charger will need to be the same watts or greater watts to run the fans.
The fans are also likely DC so make sure the charger is DC and not AC.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
06-30-2012, 10:30 AM
#4
i miss read it, it says
input 100-240V
50/60hz 0.3A
output 5V 700mA
the fans are 36V and .63A
i dont know what that means. is that too many volts or watts?
06-30-2012, 10:38 AM
#5
Electrical Contractor
input 100-240V
50/60hz 0.3A
output 5V 700mA
5V x .7A = 3.5 watts
36V x .63A = 22.68 watts
Ain't going to work.
You need 6½ times more power for those fans to work.
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to kbsparky For This Useful Post:
06-30-2012, 10:51 AM
#6
thanks! so what are the stats i need on the charger, and could i power 1 or mabye 2?
06-30-2012, 12:56 PM
#7
Semi-Pro Electro-Geek
You can't power any. Here's the deal: The power supply voltage must be THE SAME as the fan voltage. The power supply current must be AT LEAST the combined fan current.
06-30-2012, 01:22 PM
#8
Average Joe/ex-Navy IC3
Just pop over to either Radio Shack, Best Buy, local mom & pop store, and get a couple of cpu cooler fans. or computer case cooler fans. Most coolers will use the USB port, not a separate power source, so that they are portable.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
06-30-2012, 03:32 PM
#9
MOST will in fact be 12vdc since thats what rail a molex connector in a pc case will be connected to.
There are some pre assembled laptop coolers that do run off of USB but a selection of 5 v fans is not going to move a lot of air and will kill your battery.
Most laptops simply don't need it these days. If yours is especially hot underneath, I'd suggest that either you are not placing it on an appropriate surface, or the ventilation channels inside are clogged. Or both.
Do you have pets? Long hair on you or S O? Odd but true that laps are not a great place to use laptops. Either clothing or exposed flesh tends to get in the way of proper airflow.
06-30-2012, 03:39 PM
#10
Evstar, actually Radioshhack sells the 3.5 & 5 volt fans, so does BB.
06-30-2012, 04:13 PM
#11
the Musigician
Quite true. The best thing to use is a lap "pillow" that is basically a cloth beanbag with a masonite top that is hard and flat to keep the fan's airflow going.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
07-07-2012, 07:20 PM
#12
I'd did say most ... Not all... Lol
Still it's a great way to cut your runtime in half.
The Following User Says Thank You to Evstarr For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
