Landscape Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2008, 09:21 AM   #1
sweaty
Rewards Points: 276
Landscape Lighting
I have six lights along my front walkway and I really need them fixed before Halloween. I replaced all the bulbs, but only the first light went on. Why are the others not coming on?
sweaty is offline   Reply With Quote
Old 10-26-2008, 09:44 AM   #2
the Musigician
DangerMouse's Avatar
"Jonny5 need more input" are these buried wire electric? solar/battery? wired in series or parallel if elec.?
DM
Old 10-26-2008, 08:21 PM   #3
sweaty
Rewards Points: 276
They are not solar powered. I do not know how they are wired.
Old 10-26-2008, 08:35 PM   #4
The break in the wire is between the first and second lights?
Old 10-26-2008, 08:44 PM   #5
The connectors for these light are notoriously crappy. At each light there is a short piece of fixture wire (1') that clamps on to the fatter wire that runs from fixture to fixture. The wire piercing clamps/connectors are prone to failure.
You need to dig up and expose these connections and, A) squeeze them tighter with pliers, or B) replace the connection with something better.
I use standard wire nuts and a sealing compound like Scotchcote or Liquid Tape.
220/221 is offline   Reply With Quote
Old 10-26-2008, 09:04 PM   #6
Rewards Points: 6,652
Best to use Waterproof Wirenuts, then wrap with Electrical Tape, then coat with ScotchCoat Liquid tape. Will make for a good water tight connection. If you do not use the Gel Wirenuts, then wrap with Rubber tape, pulling with tension to allow for a tighter covering, then Electrical Tape, then the ScotchCoat Liquid Tape.
Old 10-26-2008, 09:19 PM   #7
Electrician
Man your good, because I could not tell that they were low voltage fixtures.
chris75 is offline   Reply With Quote
Old 10-26-2008, 10:00 PM   #8
I asked the Magic 8 ball if they were LV
Old 11-01-2008, 02:56 PM   #9
sweaty
Rewards Points: 276
Sorry, they are low voltage. And I missed my Halloween deadline.
I didn't see this 1" fixture wire. I lifted a couple fixtures out of the ground and saw only one wire coming out of it. I don't know how they are connected.
Old 11-01-2008, 04:06 PM   #10
Follow the wire Grasshoppa. It will lead you on the path to enlightment.
Old 11-01-2008, 04:36 PM   #11
Electrician
Funny stuff right there, I dont care who you are.
Homemade Landscape Lighting Randell Tarin Landscaping & Lawn Care 18 02-28-2012 12:31 PM
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
Landscape Lighting la15ota Landscaping & Lawn Care 14 07-08-2009 05:47 PM
Help me pick out landscape lighting vanamc Landscaping & Lawn Care 3 05-04-2009 08:49 PM
