Landis Gyr Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2007, 04:43 PM   #1
Landis Gyr Panel
I have a 200 amp Landis Gyr panel and service that has low utilization. I want to run a 100 amp sub panel to my new garage. I am trying to find out what 100 amp breaker will fit my existing panel and it looks like Landis Gyr and Siemens are the same company. Will a Siemens 100 amp breaker from Home Depot fit my existing panel? I think 2/0 aluminum underground cable will handle the load. Any help and other thoughts/suggestions would be greatly appreciated. Thanks.
jlazc is offline   Reply With Quote
Old 12-22-2007, 05:04 PM   #2
Never heard of Landis but here is my $.02
The breaker may "fit" but may not be "listed".
Ckeck the lug size on the breaker to see if it wil take your 2/0. I don't think so.
Use #2 copper instead.
Don't use direct burial anything ever.
220/221 is offline   Reply With Quote
Old 12-22-2007, 05:34 PM   #3
The 2/0 will fit in some breakers, but it depends on the brand. I would rather use copper too, but burrial cable will be more convienent (still considering a conduit run with copper) However, I've used the 2/0 before for outdoor/ underground use and have never had a problem. I have two homes, and I'm not at the one where I'm adding service, so thats the reason I am unable to compare breakers at this time. Thanks for your 2 cents and I'm looking for more!
Old 12-22-2007, 05:56 PM   #4
Always factor in safety and longevity along with convienence.
Old 12-22-2007, 08:04 PM   #5
Electrician philosopher
I'm curious why? That's all the POCO runs around here to 90% of the homes in ATL. I've run tons myself and never had a problem.
Andy in ATL is offline   Reply With Quote
Old 12-22-2007, 08:52 PM   #6
Rewards Points: 266
The OP is probably using a wire that size to reduce voltage drop. Aluminum conductor is more economical than a comparable copper conductor. #2 is probably not big enough for the distance. He could pigtail the larger conductor to a smaller wire to connect to the breaker.
Looking at how common directly buried cable is, I guess everyone will be replacing buried lines come spring! (sacastic)
Around here, practically all utility installed underground cables are of the directly-buried type... Primary and secondary.
I never knew Landis & GYR ever made panels. I thought they made mostly KWH meters.
junkcollector is offline   Reply With Quote
Old 12-23-2007, 10:59 PM   #7
I realize that it direct buried aluminum may be an industry standard but to ME, it's just too vulnerable.
Have you seen what one tiny pinhole in the insulation will do to AL wire? It turns to dust in a very short time. I've seen it countless times even IN conduit.
The utilities here still use AL but since the 80's have required it to be in conduit. They got tired of digging it up to fix gopher damage.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
