Lamppost Bulb - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 09:47 PM   #16
Originally Posted by frenchelectrican View Post
Try this trick for the photocell sensor get a black electrical tape and not excatally cover the photocell but make like tubelike shape and cover it in that fashon to see if that reduce the amout of the light cycling.
I have done that few time when some photocell is very senstive so try that trick to rule it out.
Merci.
Marc
I don't understand. I should try this to see if I have a bad sensor?
dinosaur1 is offline   Reply With Quote
Old 03-30-2011, 10:00 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Let me rephrase this one .,,
you know paper towel tube if so it the same idea with tape make a small tube out of tape and put it on the photocell sorta like minitunnel that will reduce the glare of background and light source hitting the photocell and I will say not to compelety close the photocell up but still give some leeway to have it functioning properly.
Hope that clear up this one.
Merci,
Marc
Old 03-30-2011, 10:40 PM   #18
Merci,
Marc
So if you shape it into a tube howndo you make it stick
Sorry still don't undertand.
Old 03-31-2011, 12:38 AM   #19
I wish I can post the photo how it done but I think one of the members have a trick how to do it. { to add a photo here }
Merci.
Marc
Old 03-31-2011, 06:12 PM   #20
Merci.
Marc
Ok I will wait to see photo.
Old 03-31-2011, 06:23 PM   #21
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
try this instead.
do this when it is dark
turn off the power to the fixture. put a couple layers of black tape over the PC. Turn the power back on. It should start up and stay on. Then, while it's still on, take the tape off and see what happens.
just out of curiosity; have you replaced the PC recently? How is the PC connected to the circuit? What color wire is fed from the hot circuit? What color wire feeds to the ballast?
Old 03-31-2011, 06:42 PM   #22
Originally Posted by nap View Post
try this instead.
No it is the original PC since it was installed in 1995 from the previous owner. I have no clue about the wires. I didn't open it yet.
Old 04-01-2011, 12:40 AM   #23
Before you do this part below do Nap's part first that is a surefire way to test if you have bad photocell.
I did not get a chance to get a photo posted here however to get into the photocell in the post you will have to unscrew the whole luminaire off from the post it will be either set screw or a screw or other means to hold the luminaire to the post when you start to lift it up it may pull the conductors like weighted down.
For ballast in post verison you should able see a clip or other means to support the ballast.
The photocell may be above the ballast or below the ballast so it will varies a bit.
So when you remove it take it easy with the conductors and you may need a good flashlight to shine down the post to make sure nothing is hung up when you try to pull it out.
Merci.
Marc
Old 04-01-2011, 07:56 PM   #24
Merci.
Marc
I am looking at it now. The light turns on and stays on for about 2-3 minutes. Then it turns off for 1-2 minutes. I believe that it does this for 30 - 45 min before staying on completely the rest of the night.
What do you think it is. Ballast? If it was the PC I don't think it would act this way or am I wrong?
Old 04-01-2011, 08:08 PM   #25
Merci.
Marc
Would it be wise to switch away from a high pressure sodium light and switch to a cfl bulb instead? A hps bulb might be generating too much heat?
Old 04-02-2011, 08:33 AM   #26
Merci.
Marc
Do you think the ignitor might also be bad?
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 10:46 PM
Tips for Removing GU10 Bulb? djdragan Electrical 5 12-12-2010 09:17 PM
Can I install a self-ballasted CFL bulb into a ballasted fixture? Daaavey Electrical 22 08-25-2010 08:52 PM
Outdoor post light - random blinking bulb handymike Electrical 9 06-14-2010 01:29 PM
Flickering Power Saver Bulb stevebooker Electrical 10 02-02-2009 08:33 AM
