Lamp Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 01:06 PM   #1
Lamp Wiring
Hi
I m putting together a lamp as part of a project and need to work out the details of the wiring (the lamp works, but i need to get the minimums and maximums worked out)
1. i am using candelabra bases like these (http://www.grandbrass.com/ShowItem.c...Base%20Sockets
2. there are four of these in total
3. power supply to the lamp will be any standard house outlet!
4. the power cord is standard lamp cord (silver.clear)
what i need to know is the MINIMUM gauge wire I can use to wire this up. I used 16 ga the test go 'round but wanted to be sure to use the least heavy gauge - can i get away with 18 for instance.
Also is there a good source for the non brassy 1/8 IP threaded rod OR is there such a thing as 1/8 IP bolts?
Ada01 is offline   Reply With Quote
Old 12-15-2011, 01:52 PM   #2
Missouri Bound's Avatar
If you are saying 4 of those bases per fixture, 18 ga. will work. The total capacity of those bases, @ 125w is a little over 4 amps. At 120 volts 18 ga. wire is acceptable for up to 10 amps. But you need to use fixtue wire, not lamp cord. Fixture wire will have a heat resistant sleeve over it..
Old 12-15-2011, 02:09 PM   #3
Thank You for the reply. The 18 ga wire will give me a little more flexibility (literally) in terms of the design.
I will be getting wire like this (but in 18 ga)
http://www.radioshack.com/product/in...ductId=2049745
Old 12-15-2011, 02:48 PM   #4
That's not fixture wire. Go to a good hardware store or electrical suppy for the wire.
240V Floor Stand Lamp Metallo Electrical 24 01-02-2011 02:20 PM
Broken wiring for outdoor lamp secutanudu Electrical 63 07-13-2009 10:48 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
