Lamp Post GFI Protection - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 08:26 AM   #1
Lamp Post GFI protection
I'm installing a lamp post in my front yard soon. Here are a few details of the circuit:
-Power comes from a switch inside of the front door.
-Wire (14-2 nm-b) runs into the basement and along the floor joists.
-15A circuit
-Goes into 3/4" conduit and down the basement wall, into a junction box, out into an 3/4" LB, then out into the yard.
-Everything after the junction box will be 12-2 uf in 3/4" conduit (I had 12g laying around so i'm using it.)
-18" burial depth
1.) If i would like to GFI protect this circuit, does it make sense to use a GFI recepticle in the junction box?
2.) Will this be a problem if the outlet is only powered when the lamp post is on?
3.) I had initially not planned on the recepticle, so the junction box is about 36" off of the floor. Since the recepticle is used for light protection only, will this be a problem that it is this high off of the ground?
I do have a few others, but i may get these answered inadvertently. FYI this will be inspected.
jonrya91 is offline   Reply With Quote
Old 08-06-2012, 08:31 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
1) This will be fine, although unnecessary.
2) Shouldn't be.
3) No
The Following User Says Thank You to k_buz For This Useful Post:
jonrya91 (08-06-2012)
Old 08-06-2012, 10:26 AM   #3
Master Electrician
you can get a dead front gfci as well if you don't want to put in the receptacle.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 09:31 AM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
GFCI for the Lamp Post (GFCI for circuit that is fed Power from light) jamiedolan Electrical 7 02-25-2009 10:50 PM
