Lamp Post Bulb Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2014, 03:13 PM   #1
Rewards Points: 2,166
Lamp post bulb help.
This lamppost must be 30 yo like the house.
Its had a yellow bulb that goes on dusk till dawn. I don't know where the sensor is but that probably doesn't matter.
It just stopped working.
The bulb had to be 4 yo. I took the top off and I see there was a curly bulb inside of a yellow case. The yellow case is broken.
Can I just buy a replacement yellow bulb and throw away the broken yellow case? I searched bulbs at Home Depot and didnt see any with the yellow case.
Startingover is offline   Reply With Quote
Old 10-07-2014, 03:15 PM   #2
Old 10-07-2014, 03:34 PM   #3
Rewards Points: 13,732
You can buy yellow bulbs like that and not need the cover.
The sensor is what that bulb is screwed into by the looks of it.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
clw1963 (10-07-2014), Startingover (10-07-2014)
Old 10-07-2014, 08:58 PM   #4
With the broken yellow glass I want to turn the breaker off when I take the old bulb out. But, no breaker is labeled "lamp post". Several breakers are labeled "lights".
So would it hurt if I just turned the main breaker off? I sure don't want to mess anything up.
Old 10-07-2014, 09:12 PM   #5
Rewards Points: 1,832
Yes you can turn off the breaker. Just unscrew the whole thing.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
Old 10-08-2014, 03:32 PM   #6
Aha, just noticed a little circle, a few inches below the light, on the post facing south and now know that is the sensor!
Old 10-08-2014, 06:01 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,360
If the sensor is separate from the light bulb itself ?
Then just buy another yellow CFL lamp
And screw it in
Get the biggest one you can
I think they call them BUG lights ?
Get a good quality one
so you can forget about it for a good number of years again.
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Startingover (10-08-2014)
Old 10-08-2014, 08:51 PM   #8
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Not sure there's much in "high quality" bug CFLs. But the typical $5 one from orange box last at least a couple years of always on for me.
clw1963 is offline   Reply With Quote
The Following User Says Thank You to clw1963 For This Useful Post:
Startingover (10-09-2014)
Round metal lamp post DJM1955 General DIY Discussions 11 08-27-2012 02:32 PM
Post lamp power NAIL BENDER Electrical 18 12-22-2011 09:18 PM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
Outdoor post light - random blinking bulb handymike Electrical 9 06-14-2010 01:29 PM
GFCI for the Lamp Post (GFCI for circuit that is fed Power from light) jamiedolan Electrical 7 02-25-2009 10:50 PM
