Old 06-11-2008, 11:18 PM   #1
Lamp cord repair
I have an old lamp that has a short at the base. It's on the end that I could never figure out how to remove without cutting the cord on both ends. I don't know what its called. I managed to open one before, but couldn't close it again.
Sliding Man is offline   Reply With Quote
Old 06-12-2008, 12:18 AM   #2
Lamp cord repair
Do you need to remove and re-install the strain relief? You should be able to get by with a pair of ordinary slip-joint pliers, but there are special tools for the purpose. Google for "Heyco strain relief pliers" or see this Web page: http://www.heyco.com/pages/products/section_2/2-27.html.
Matsukaze is offline   Reply With Quote
Old 06-12-2008, 10:51 AM   #3
J. V.'s Avatar
Lamp cord repair
The only safe way to repair a bad cord is not to repair it at all. Replace it. If you don't know how then find someone who does or trash it.
I bet if you take your time and really look at this with an open mind you can replace this cord. Give it a shot. The cord had to be installed, so it must be able to be uninstalled. Especially if it is an older fixture. Good luck.....John
Old 06-12-2008, 11:07 PM   #4
Lamp cord repair
I'd hate to replace the entire cord. I'm trying to keep it original looking.
Old 06-13-2008, 12:26 PM   #5
J. V.'s Avatar
Lamp cord repair
In the picture you posted it looks like the connections are fine and inside the fixture. I guess I really don't understand what you want to do. Take a pic of the fixture and the cord. The picture you posted looks like the inside of a florescent fixture, and this connection looks fine other than the tape.
Old 06-13-2008, 04:43 PM   #6
Lamp cord repair
The pic I posted originally is something I found on the net. I didn't post an actual picture because my camera is bad. This is the best picture I can get.
The cord is bad right at the relief. I wanted to remove that, repair the cord and put everything back the way it was.
Old 06-13-2008, 04:46 PM   #7
Electrical Contractor
Lamp cord repair
If you remove the relief, slide the cord into the lamp, repair the bad wire, you will a shortened cord. Will you be able to live with that?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-14-2008, 02:33 PM   #8
Lamp cord repair
As long as I can put the relief back, yes.
Old 06-14-2008, 03:59 PM   #9
J. V.'s Avatar
Lamp cord repair
Remember to look at it good. The strain relief may have a tab that when pressed down will allow you to remove it from the fixture. Then see how the wire is removed, so you can push the bad part up into the fixture and re-connect. If the strain relief is molded to the wire (highly unlikely) you can buy strain reliefs, lamp cord and male plugs at the store.
Old 06-17-2008, 12:19 AM   #10
Lamp cord repair
Thanks.
repair power cord on dishwasher MattCoops Appliances 8 03-05-2012 04:36 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 09:12 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
