Lamp Chain Stuck - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 08:43 PM   #1
Rewards Points: 123
lamp chain stuck
I have a standing lamp that has two chains for two light bulbs. One of the chains will not move so I can turn the light on. How do I fix the problem?
jerry1967 is offline   Reply With Quote
Old 11-19-2008, 08:50 PM   #2
dSilanskas's Avatar
Get a new socket
dSilanskas is offline   Reply With Quote
Old 11-19-2008, 08:53 PM   #3
1st unplug lamp. try to spray a little wd40 and gently pull chain, if that does not work y9u will have to open the fixture and clear the stuck chain. Do not worry it is a easy fix..
charlie C is offline   Reply With Quote
Old 11-19-2008, 09:01 PM   #4
Rewards Points: 1,538
Although I cannot say for sure, there is a good chance that the switch assembly in the socket is wearing out and if you succeed as described above, another failure is likely a short time later.
AllanJ is online now   Reply With Quote
Old 11-20-2008, 10:26 AM   #5
Rewards Points: 204
This pull chain switch is easily removed and can be replaced. The little brass hole the chain goes through is actually the holding nut. Unscrew it and the switch can be removed and replaced.
Old 11-20-2008, 11:53 AM   #6
bradnailer's Avatar
You can generally find a replacement chain switch at homeless depot or lowes.
bradnailer is offline   Reply With Quote
Old 11-20-2008, 07:58 PM   #7
Rewards Points: 123
thank you everybody
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
halogen desk lamp Banker 21 Lamp bh4bhwgm Electrical 3 09-29-2008 04:55 AM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 07:35 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 08:12 PM
