Labeling Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-26-2009, 04:24 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Originally Posted by Speedy Petey View Post
I have a few different formats of panel directories in spreadsheet format.
I like to use sticky backed full sheet protectors stuck to the inside door of the panel. This way the customer can remove the sheet and make changes if they need.
That is the way I do it also. I also add my name and phone number, in case they ever need me.
In plant work I include where the panel is fed from.
Old 09-20-2013, 06:52 PM   #17
Rewards Points: 528
Panel diagram info
On the main panel diagram written to the left on the inside of door is it required that amps be listed with each circuit # and location ?Mine only has the breaker # and what it goes to ..
hidden1 is offline   Reply With Quote
Old 09-20-2013, 07:07 PM   #18
jbfan's Avatar
Rewards Points: 464
No, just the breaker # and where it goes.
Old 09-24-2013, 01:11 PM   #19
Rewards Points: 180
thanks.
-should this chart be ok-sent in later post - when inspected .i put the circuit # at the breaker .Ive seen some use color codes to help also but i just want to pass on chart.
hidden 1 is online now   Reply With Quote
Old 09-24-2013, 01:54 PM   #20
most panels are labeled with odd on the left and even on the right. this is usually stamped into the metal by the breaker positions. as long as the number on your schedule matches with the number next to the breaker, you'll be fine.
itsnotrequired is offline   Reply With Quote
Old 09-24-2013, 04:42 PM   #21
Rewards Points: 180
Old 11-29-2015, 10:58 PM   #22
Rewards Points: 2
Hi Scuba Dave - Realize this is and older message of your's but could you email me the spreadsheet file/templates you show here.
Thanks - Steve
Spednsteve57 is offline   Reply With Quote
Old 11-30-2015, 12:28 PM   #23
Licensed electrician
Rewards Points: 1,608
It does not take much to create a spreadsheet on your own.
Old 11-30-2015, 01:44 PM   #24
Rewards Points: 422
I have a panelboard schedule on an Excel spreadsheet - if anyone wants it, just PM me your email address. See attached in pdf format.
Pharon is offline   Reply With Quote
Old 11-30-2015, 01:59 PM   #25
GrayHair's Avatar
Rewards Points: 998
Use CAUTION printing adhesive labels
A word of caution on printing adhesive labels.
I was on a service call at an office when they trashed a brand-new color laser printer while printing adhesive labels. I guess the heat from the fusing element caused the adhesive to soften, the labels to release from their backing and wrap around the rollers.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 11-30-2015, 07:09 PM   #26
Rewards Points: 108
For labeling the end of the wire inside of the house, I wrote the breaker number on the back of the wall plate with a sharpie. This way if I am working on something, all I need to do is take off the wall plate and I know right away which breaker to switch off.
zolakk is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Existing panel box labeling Pete2826 Electrical 2 12-23-2008 11:00 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
