Old 12-02-2005, 04:21 PM   #1
Question
Kohler Whirlpool not turning off
My whirlpool starte acting weird recently. After running for a while, I cannot turn if off by pressing the air button. I have to turn off the master panel and waited till the next morning for it to work again. The electricians found not problem with wiring. Has anybody heard of this kind of problem before? Any advice is appreaciated!
tnt2006 is offline   Reply With Quote
Old 12-03-2005, 01:13 AM   #2
Your problem is 1 of three things...1st (and most likely) is either a defective bell or static switch, or it's supply tube. when you press the ON buttton you send a small burst of air through a plastic tube to the control unit where there is little switch that has a diaphram w/ 2 contacts that touch from the burst of air. This keeps all electrical away from you. anyways if the tubing cracks or the diaphram ruptures or contacts become corroded your unit will not function properly. last possible cause could be the contactor is sticking and needs replacing
playintennis5274 is offline   Reply With Quote
Old 12-04-2005, 10:57 AM   #3
This is really out of my knowledge, but thank you so much for replying. I'm glad I'm still in the 1 year warranty.
Old 12-30-2005, 03:14 PM   #4
I have the oposite problem. Just had a bath refinished and decided to keep the Kohler Whirlpool. Unfortunately after it was completed and we filled the tub it no longer turns on. Checked the outlet that it is connect too and it appears to be working. Wondering if it could be the switch. Any idea how to test this air switch?
dnw150 is offline   Reply With Quote
Old 06-09-2009, 02:49 AM   #5
I have the same problem too, join the club. It is not as bad as it sounds. what actually happens is that the bubbles from the bath get in the airt tube and prevent the air burst getting to the diaphram. I have a GFC outlet in the bathroom and if it happens I just flip that and blow out the on / off switch and then reset the GFC outlet and it is back to normal. Bubbles......its always the bubbles.
joatmon420 is offline   Reply With Quote
Old 06-09-2009, 07:31 AM   #6
My License Ain't 4 Sale..
If the previous posters haven't fixed it by now, they ain't gettin' it fixed
Whirlpool tub doesn't work Scott_K Plumbing 15 05-04-2012 08:12 PM
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 07:33 AM
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
tile step into whirlpool ekaplan1020 Remodeling 1 04-09-2006 11:48 AM
