-   -   Kohler Whirlpool not turning off (http://www.diychatroom.com/f18/kohler-whirlpool-not-turning-off-1403/)
tnt2006 12-02-2005 03:21 PM
My whirlpool starte acting weird recently. After running for a while, I cannot turn if off by pressing the air button. I have to turn off the master panel and waited till the next morning for it to work again. The electricians found not problem with wiring. Has anybody heard of this kind of problem before? Any advice is appreaciated!
playintennis5274 12-03-2005 12:13 AM
re: whirlpool not turning off
Your problem is 1 of three things...1st (and most likely) is either a defective bell or static switch, or it's supply tube. when you press the ON buttton you send a small burst of air through a plastic tube to the control unit where there is little switch that has a diaphram w/ 2 contacts that touch from the burst of air. This keeps all electrical away from you. anyways if the tubing cracks or the diaphram ruptures or contacts become corroded your unit will not function properly. last possible cause could be the contactor is sticking and needs replacing
tnt2006 12-04-2005 09:57 AM
This is really out of my knowledge, but thank you so much for replying. I'm glad I'm still in the 1 year warranty.
dnw150 12-30-2005 02:14 PM
I have the oposite problem. Just had a bath refinished and decided to keep the Kohler Whirlpool. Unfortunately after it was completed and we filled the tub it no longer turns on. Checked the outlet that it is connect too and it appears to be working. Wondering if it could be the switch. Any idea how to test this air switch?
joatmon420 06-09-2009 01:49 AM
i have the same problem
I have the same problem too, join the club. It is not as bad as it sounds. what actually happens is that the bubbles from the bath get in the airt tube and prevent the air burst getting to the diaphram. I have a GFC outlet in the bathroom and if it happens I just flip that and blow out the on / off switch and then reset the GFC outlet and it is back to normal. Bubbles......its always the bubbles.
InPhase277 06-09-2009 06:31 AM
If the previous posters haven't fixed it by now, they ain't gettin' it fixed:laughing:
Randy Tate 08-29-2014 09:41 PM
plumber
I have a customer with this problem, but theirs has an low voltage switch, it is a very small circuit board with telephone wire going to motor.
