Kohler Whirlpool Installation Bypass Air Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 04:22 PM   #1
Kohler whirlpool installation bypass air switch
My contractor installed a kohler whirlpool for me that can only be turn on by a switch on the wall (like a light switch). Would this installation cause any problem in the future? (for now, it is just a little inconvenient because one can't turn off the jets until get out of the pool? ). Kohler support told me that this installation will void the warranty on the product.
Is it easy to fix it and revert back to standard installation, probably do it myself?
Jet001 is offline   Reply With Quote
Old 04-29-2010, 05:35 PM   #2
Electrical Contractor
kbsparky's Avatar
There was a time where those were required to be controlled by a timer switch, to prevent one from staying too long in the tub. You had to get out of the tub to reset the timer.
But those were not supposed to replace the built-in air switch, only supplement it. Keep the wall switch (replace it with a 15 minute timer if you like), but reconnect the air switch.
-KB
Tags
kohler , switch , whirlpool install
Kohler Whirlpool not turning off tnt2006 Electrical 6 08-29-2014 10:41 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
adding inline heater to Kohler K1148 whirlpool tub rpbdiy Plumbing 1 07-30-2009 07:51 PM
Bypass a light switch skyhigh82 Electrical 6 03-25-2009 07:30 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
