Knockout Plug And Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2008, 06:52 AM   #1
Florida Cracker
Knockout Plug and Breaker Question
Two questions about an investment property I am working on.
1. I just removed a double pole breaker from my panel- do I need something to cover the holes in the panel cover where the breaker was to be up to code?
2. I discovered that the 220 volt hot water heater is wired using two single pole 20 amp breakers that are next to each other (vertically) in the panel.
Is this up to code?
Thanks.
Jack A. Trades is offline   Reply With Quote
Old 06-14-2008, 06:57 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
What size was the 2 pole breaker you removed? If it was a double 20 then use that to feed the water heater and leave the 2 singles as "spares". You need a double pole for the heater, and if you do remove a breaker(s) you will need a filler plate for that space. Is the wire feeding the water heater 10 or 12?
wirenut1110 is offline   Reply With Quote
Old 06-14-2008, 07:08 AM   #3
Florida Cracker
Looks like 10 wire- its weird though because it is two red wires and a green coated wire. I think the original owner or his buddy wired the heater.
The breaker I took out was too large to be used for the water heater.
I found this out because I needed to remount the h/w disconnect, went to the breaker box and couldn't find a double pole breaker for the h/w heater, so I opened the panel and figured out that someone had half-assed teh install.
Old 06-14-2008, 07:13 AM   #4
Rewards Points: 510
If it's #10 then get a double pole 30 and put it in the space that you removed the breaker and leave the 2 20's for spares.
Old 06-14-2008, 09:42 AM   #5
jbfan's Avatar
Rewards Points: 464
And use one of the spare breakers to fill the space in the panel.
Works better than a filler strip.
Wiring a compressor scrapin Electrical 25 03-18-2012 11:35 PM
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 12:57 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 09:22 PM
