Knockout In Panel.. Any NEC Section? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 11:25 PM   #1
Knockout in panel.. Any NEC section?
Hi folks,
I'm running a 1 1/4" PVC to my subpanel which is recessed into the wall. Coming into the panel from the bottom, I see two large knockouts, one is in the center and ther other is closer to the side of the panel. I'd like to use the one in the center so I can drill through an ideal spot in the sill and run my pipe straight down. I don't want to use an offset if it is not necessary.
But, the knockout in the center looks to be for a larger diameter like 1 1/2" to 3". The knockout closer to the side, the one I don't want to use, looks like 3/4" to 1 1/2". These are multi size knockouts.
I can get a male adapter in 1 1/2" and use a reducing fitting to accommodate the 1 1/4" pipe which will fit the center knockout. I can't find anything in the 2008 NEC that covers anything about knockouts. So, I think this would be code compliant, because it will be inspected.
Can someone ease my concern?
Thanks for the help.
Rick
RM575 is offline   Reply With Quote
Old 08-18-2012, 11:29 PM   #2
Rewards Points: 14,014
Your plan will work.
Old 08-18-2012, 11:54 PM   #3
Thanks Joe,
I think so too. Hope the city inspector does as well.
Old 08-19-2012, 04:46 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If you're using 1 1/4" pipe, just get a 1 1/4" TA and use 2- 1 1/2 X 1 1/4 reducing washers.
wirenut1110 is offline   Reply With Quote
The Following 3 Users Say Thank You to wirenut1110 For This Useful Post:
brric (08-19-2012), Jim Port (08-19-2012), stickboy1375 (08-19-2012)
Old 08-19-2012, 07:23 AM   #5
Rewards Points: 2,516
Originally Posted by RM575 View Post
Hi folks,
Rick
You can do what you want which is this I assume?
hammerlane is offline   Reply With Quote
Old 08-19-2012, 07:26 AM   #6
or like wirenut said just use a reducing washer on the 1.5 knockout
Knockout in panel.. Any NEC section?-red-wash.jpg   Knockout in panel.. Any NEC section?-reducingwasher.jpg
Old 08-19-2012, 07:42 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would bet money there is a 1 1/4" KO in the bottom of the sub panel and he is just mistaken about the size. I can't say that I've ever seen a 3" KO in a residential panel.
Old 08-19-2012, 12:22 PM   #8
The possibility is likely.
Old 08-19-2012, 12:49 PM   #9
Thanks for the replies. I like the option of the reducing washer. I've used those before and don't know why I didn't think of that. I guess I'm a little nervous about building inspectors reviewing my work.
The panel has a 1 1/4" knockout in a spot where it would require me to use an offset to send my pipe through the sill plate at the right spot. The larger set of knockouts are perfectly positioned for a straight pipe run and that is where I'll need the reducing washer.
I measured the largest knockout on my panel with a tape measurer and it is exactly 3" in diameter, which doesn't mean a 3" pipe, but more likely a 2" with a reducing washer.
I really appreciate your help, thanks again.
Old 08-19-2012, 01:06 PM   #10
time to get to knockin out
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
