Knockout On Main Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 04:56 PM   #1
I am installing a new 200amp main breaker box, the old box has knockouts with up to 7 wires coming in through one knockout (with a connector). On the new box what is the max amount of wires that can come through a single knockout?
rekish is offline   Reply With Quote
Old 06-24-2012, 05:05 PM   #2
wareagle's Avatar
You can not push conductors thru a knock out with out protecting the conductors. You will need some type of connector. The connector will determine how many conductors you can install. It will have the number such as 2 #12 and 2 #10 ect
Cable Connector
wareagle is offline   Reply With Quote
Old 06-24-2012, 07:34 PM   #3
Connector Types
Can I use the Halex Plastic Hit-Lock Connectors, they are UL Listed.
Old 06-24-2012, 07:47 PM   #4
wareagle's Avatar
Does your installation meet the requirements as shown here?
http://electrical.hardwarestore.com/...rs-618024.aspx
Old 06-24-2012, 08:05 PM   #5
Licensed electrician
Rewards Points: 1,786
Unless you have a surface mounted panel and several other conditions, you will need to use multiple knockouts for the cables. Check the cable size combinations on the package for the connectors to see how many cables are allowed in each connector.
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Remove Main Breaker from Subpanel fblankinship Electrical 5 10-28-2010 07:11 PM
Sub-panel selewis Electrical 23 02-21-2010 10:52 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
