Knock Snow/ice Off Power Line ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 10:44 AM   #1
Rewards Points: 236
knock snow/ice off power line ?
looking out my window. i see that my line coming to the house has about 2" of snow, ice ? on it. and it is somewhat windy. could/should i take my fiberglass pole of try to knock some of it loose ? it would suck for this line to break.
Fix'n it is offline   Reply With Quote
Old 01-05-2014, 10:47 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No you shouldn't...for a variety of reasons.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
jbfan (01-05-2014), Jim Port (01-05-2014), plummen (01-05-2014), Speedy Petey (01-05-2014)
Old 01-05-2014, 10:48 AM   #3
An old Tradesmen
Rewards Points: 6,846
No. It would bite worse if it came down while you were knocking the snow and ice off.
The Following User Says Thank You to beenthere For This Useful Post:
Old 01-05-2014, 11:00 AM   #4
Rewards Points: 236
what reasons ? just try'n to learn.
Old 01-05-2014, 11:03 AM   #5
k_buz's Avatar
If the line was going to come down, it would come down when you hit it. You'd be standing under it, in snow.
If there was any deterioration of the drop, you could short it out and do damage to others connected to the system. You could also be held liable if it was traced back to you.
Those power lines are not your property. If you are that concerned, call your POCO.
Old 01-05-2014, 11:10 AM   #6
turn on all the electric stuff in your house, the extra current will heat the line and melt the ice off.
itsnotrequired is offline   Reply With Quote
The Following 2 Users Say Thank You to itsnotrequired For This Useful Post:
bbo (01-05-2014), Know A Little (01-05-2014)
Old 01-05-2014, 11:16 AM   #7
bbo
or get a really really big hair dryer.
or best yet, wait till spring.
bbo is offline   Reply With Quote
Old 01-05-2014, 11:32 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... Leave it alone, 'fore ya get yerself Hurt, Badly,....
Mother Nature put that stuff there, 'n she's tryin' to knock it off there, with her Wind,...
Old 01-05-2014, 11:49 AM   #9
Rewards Points: 236
ok. well, i have to go do some snow blow'n. so i will see if i can hire a squirrel to run on the line.
Old 01-05-2014, 03:45 PM   #10
Rewards Points: 236
the winds picked up and knocked the stuff off.
Old 01-05-2014, 03:54 PM   #11
An old Tradesmen
Cool. Now go inside and enjoy your electric until a pole gets hit by an out of control car.
Old 01-05-2014, 04:05 PM   #12
Rewards Points: 236
lol. it would most likely be a branch falling on a wire somewhere.
Old 01-05-2014, 04:12 PM   #13
Rewards Points: 6,652
If it is really bad, you can put in a ticket, and hope they will come around to try and knock it off.
Old 01-05-2014, 10:23 PM   #14
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Ice is a very terrible conductor, I would just get on a ladder and tap/move it with a hockey stick or other non conductive stick. A 2x4 or something that has been sitting in the garage is fine, even if it's "wet" it's going to be frozen. Wont conduct anything. It's only 240v, it's not going to arc at you or anything. Higher voltages would potentially be more dangerous to deal with in this regard. Also remember that lien is insulated, so you could technically use a metal pole, just, don't do that, because there could always be a break in the insulation.
Though, unless it looks very bad you can probably just leave it alone. I'd call the hydro company first just to see what they say. If they'll send someone and do it for free then may as well get them to do it.
Old 01-05-2014, 10:47 PM   #15
Rewards Points: 1,002
I don't know if your being facetious, or got a screw loose
Anti-wingnut is offline   Reply With Quote
Exterior Painting around Power Line kimberland30 Painting 14 05-21-2013 11:33 AM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
wiring in line light switch on power cord basicbrand Electrical 4 12-08-2009 09:36 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
moving incoming power line and grounding rod amakarevic Electrical 3 07-28-2008 11:24 PM
