Knob And Tube Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 12:40 PM   #1
knob and tube wiring
how do i tell which lead of the nobe and tube wire hooks to the white or black lead of romex?
diybuck is offline   Reply With Quote
Old 04-21-2011, 12:43 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
You are not allowed to make changes or additions to knob & tube wiring.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-21-2011, 11:58 PM   #3
Test for voltage potential by measuring from a ground point .
I usually plug an extension cord into a receptacle with a good ground.
Run the extension cord to where you wish to test and use its ground pin as a reference point.
You can also buy a battery powered tester that signals when its near a conductor with voltage on it. Mine cost me $20.
Some jurisdictions may not allow k&t revisions, but not all!
Old 04-22-2011, 12:13 AM   #4
" Euro " electrician
frenchelectrican's Avatar
If you can able run new cable to get around the old T&K you will be fine and per NEC code we can NOT extend the old T&K or ungrounded romexs so give you a head up on that one.
Basically the same rules I Have in Paris France.
Merci,
Marc
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Knob and tube wiring (again!)...... sktn77a Electrical 4 04-06-2010 08:55 PM
Knob and Tube wiring. bronco2 Electrical 8 10-03-2009 12:36 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 10:50 AM
