Old 12-20-2008, 07:42 PM   #1
knob and tube question
i have knob and tube and i noticed and read a few of the posts here but i need some advice on the one that i have. if you notice the pics i have attached you will notice that in one pic it is being tapped to a junction box and then it continues to another. i want to remove this knob and tube and would like to know if i cut the wire to one of the junction boxes will that tell me if it feeds the other as this one line that i want to eliminate seems to run only to a switch light and not to the circuit breaker box. also how can i tell which one is hot and neutral as there is a combination of romex, knob and tube, when i followed the knob and tube wiring it seems to go from the light switch i want to disconnect to the first junction box which shows the taps. any help would be greatly appreciated.
knob and tube question-basement-003.jpg   knob and tube question-basement-006.jpg   knob and tube question-basement-007.jpg
marin001 is offline   Reply With Quote
Old 12-20-2008, 07:53 PM   #2
My License Ain't 4 Sale..
Your best bet is to get rid of that knob and tube. But to answer your question, you need a multimeter or test light in order to determine which wire is hot. If you have a verified proper receptacle, you can use an extension cord plugged into it. The long slot on the extension cord will be the neutral. If you test from the unknown wire to the neutral on the cord, you will either get a reading, if the wire is hot, or no reading if the wire is dead or neutral.
Old 12-20-2008, 08:05 PM   #3
Ehhh...I would just replace that knob and tube. Does that bx (armored cable) have a little silver wire inside of it?
rgsgww is offline   Reply With Quote
Old 12-20-2008, 11:57 PM   #4
i will check to see. i do want to replace the knob and tube, but i just don't know if i remove it if that will effect the rest of the house as the lights, outlets in the living room and upstairs bedroom will be effected. the third pic which shows the second junction box that has bx running to the breaker box i believe is what's giving the knob and tube power. should i just cut one of the wires of the knob and tube to see what happens????
Old 12-21-2008, 12:06 AM   #5
DIYer
You could, if the power is off at the breaker. Since you don't seem to be sure what goes where, you need to use a voltage probe to confirm it's dead before you go cutting that, or you'll ruin a pair of pliers and possibly your day.
As you implied, it's entirely possible that this K+T serves a large portion of your house. Back then only a few circuits served the entire house.
Gigs is offline   Reply With Quote
Old 12-21-2008, 09:00 AM   #6
Those pictures pretty much look identical to my crawl space; a combination of knob-and-tube, Bx, and NM of all vintages. I'd like to completely rewire but I have certain concerns that a fairly straightforward job will turn very complicated, very quickly.
PirateKatz is offline   Reply With Quote
Old 12-21-2008, 12:43 PM   #7
Res Ipsa Loquitur
The ideal situation is to replace as much and eventually all the knob/tube that you have. You do need to know the nature of the connections though (black, white, incoming or outgoing). This will take some investigation with a gauge/test light and then I would use some white electrical tape to mark off the neutral wires. Interesting, the hole size used for a new romex style cable 14/2, 12/2 is about the same as one tube! Progress in quality of conductor insulation!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 12-21-2008, 04:49 PM   #8
i believe the knob and tube is being feed by the bx cable in the back(3rd pic) if so then at least getting rid of the knob and tube is going to be a little more easier, the only thing i have to figure out is how to feed the first junc box. since today is sunday church first so tomorrow will be a fun day.
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 03:55 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 11:50 AM
knob & tube wiring TrevJo Electrical 3 06-08-2005 03:14 AM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
