Knob And Tube & Panel Change Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 04:00 PM   #16
Journeyman Wireman
Rewards Points: 150
Based on the pictures, I would opt for a full service upgrade which would include new meter base, riser, feeder wire and electric panel and proper grounding and bonding of said service. If you are going to gradually rewire/add more circuits will want additional capacity available.
This could be a DIY project if you had good support from your local power company (regarding the construction of the service) and from your local AHJ (authority having jurisdiction) regarding permitting and panel construction.
Or you could hire and electrical contractor who could do a full service change in 1-2 days. Then you could gradually install new branch circuits off of the new panel. Where are you located? Someone on this forum could probably give you a ballpark figure for the cost of such upgrade.
Jupe Blue is offline   Reply With Quote
Old 10-10-2009, 07:03 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Now with the photo what Joed fixed here so we can see it more clear and yeah you have old school 120v 30 amp service you denfinely need new service upgrading the smallest service size they allowed per NEC code for resdentail useage is 100 amp.
There is few ciritcias you have to follow.,,
No load centre in bathroom
No load centre behind kitchen cabents
those two items above that is a major no no per NEC codes.
You will need new meter socket , new riser , new load centre, new ground rods etc
So it can be DIY only if your local codes do allow it otherwise electrician come out and install the correct service that useally a day job otherwise will make a arrangement for longer power outage.
The total cost for service upgrade will depending on the electrician bid and what type of materals they will be using.
Old 10-11-2009, 03:20 AM   #18
Thank you for your kind answers and feed back, I am in southern california.
jwd is offline   Reply With Quote
knob and tube question marin001 Electrical 7 12-21-2008 03:49 PM
Knob and tube wiring PAULYBOY Electrical 1 03-28-2007 06:20 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 10:50 AM
