Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 12:19 PM   #1
knob and tube
Is it safe to have a knob and tube go into a junction box with Romex coming out of it then bury it under a floor board in an attic? I am doing some work in my attic and came accrossed this under a floor board when tracing the connection from my light switch
Hunter25 is offline   Reply With Quote
Old 02-24-2011, 12:24 PM   #2
DIYer
You can't block access to the junction box, but other than that, it sounds OK.
If you could make it possible to pull up the floor board there without damaging anything or removing trim, it should be OK.
Gigs is offline   Reply With Quote
Old 02-24-2011, 12:36 PM   #3
That I can fix. I was just concerned whether or not you could have know and tube going in and romex coming out.
Old 02-24-2011, 05:53 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
As long as the j-box is left accessible. If you're going to be opening the wire joints, be sure the black of the romex is tied to the 'hot' of the k&t and the white to the k&t neutral for correct polarity. This week I worked on a k&t house. Used an extention cord plugged into a known grounded GFI to test which k&t wire was which. Also, you have to be very careful when working on k&t wiring...many times the neutral was used (or ends up getting used) for more than one circuit, so just because the breaker is off on the circuit you're working on, doesn't mean the neutral is dead.
Kyle
Old 02-25-2011, 06:12 AM   #5
That's good to know! I will definitely watch for that and check it twice. Thanks for the advice. I just worry about fire hazzards. I'm not great with electrical and that is always my biggest fear.
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
looking at a house with "some" knob and tube shaner123 Electrical 8 02-08-2011 04:56 PM
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 09:34 AM
knob and tube question marin001 Electrical 7 12-21-2008 03:49 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
