Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2009, 08:38 AM   #1
mikethetinman
knob and tube
I have knob and tube wiring in ceilings. I installed a new sevice breaker panel . Now I am identifieng all wires throughout the house.I am remodeling the house, one room at a time. How do I ''dead end" knob and tube wiring so that when I get to the other rooms I can upgrade the wiring?
shockedagain is offline   Reply With Quote
Old 11-26-2009, 11:51 AM   #2
Rewards Points: 1,548
Each wire end whose other end is not known to be disconnected must be taped off individually and be in a junction box (or outlet box) with a visible (accessible) cover. Two or more loose ends may share the same box.
A section of wire both ends of which are disconnected may be buried in the wall, preferably with labels at each end.
When you cut away a piece of knob and tube wire little by little, then the box that used to hold the loose end must be relocated to where the loose end now is until you get to a T joint or another outlet box at which time the extra box can be removed for good.
(The T joint, pre-existing, does not have to be enclosed in a new box until two legs are cut away and the third leg therefore becomes a loose end.)
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 09:34 AM
knob and tube question marin001 Electrical 7 12-21-2008 03:49 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 10:50 AM
