Kitchenaid Ice Dispenser Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 07:26 PM   #1
Question
Kitchenaid Ice Dispenser problem
I have a KitchenAid Refrigerator KSCS25INSS and the Ice Dispenser stopped working. All the other ice maker functions work, makes ice, water dispenses ok. Any knowledge of what to look for?
CECILG is offline   Reply With Quote
Old 11-20-2008, 08:15 PM   #2
There should be some sort of electrical switch which activates when the lever is pressed. Look up inside and see if the switch is being activated.
If you have a round coil of wire in the ice compartment which turns to bring the ice forward, be sure it can rotate and is not "glued stuck" with ice.
Some of these compartments come out. Be sure it is all the way back and installed properly.
Other than that, there should be a wiring diagram in the motor compartment. Get out your electrical meter and start tracing circuits. If you don't know how to use a multi-meter, call an appliance repair person.
Billy_Bob is offline   Reply With Quote
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
GE Profile Ice Cube Dispenser Problem homebrewer Appliances 1 12-20-2006 10:24 PM
