Kitchen Wiring Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 06:54 PM   #1
Rewards Points: 77
Hi. I am wiring a new kitchen. So far I have ran the following circuits:
circuit 1 20 amp receptacles
circuit 2 20 amp receptacles
circuit 3 20 amp dedicated to a window air conditioner
circuit 4 15 amp overhead lights
Can anyone tell me what the requirements are for:
the dishwasher
the garbage disposal
the microwave oven
Do these so called fixed appliances require their own separate circuits, or can they share wiring added so far, or perhaps an additional circuit. Seven circuits for a small kitchen seems excessive to me.
Also, I was planning to plug the refridgerator into whatever wall receptacle is convenient.
Thank You
SS396 is offline   Reply With Quote
Old 10-30-2008, 07:27 PM   #2
Built in micro = 20 amp circuit
DW/Disp = 20 amp circuit (generally)
Refer can go with the counter top receps. Bring the home run to the refer so it's not GFCI'd.
220/221 is offline   Reply With Quote
Old 10-30-2008, 09:10 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I agree, except about the refer. Although it is allowed to be on the small appliance circuits I never do this. The refer always gets it's own circuit. 15 or 20 amp depending on the unit. Typical resi grade unit gets 15A.
Old 10-31-2008, 07:49 AM   #4
Rewards Points: 77
Are you saying that the dishwasher and disposal can be on one twenty amp circuit, or that they must be on their own individual circuits?
In addition, now we are talking about the refer being on it's own circuit.
I guess that means 8 home runs to the kitchen or possibly 7 if the disposal and the d/w are combined?
Old 10-31-2008, 08:40 AM   #5
RippySkippy's Avatar
DW/Disposal can run on a 12/3 sharing the neutral if you wanted...use a tandem breaker. Put the MW and refer on it's own circuit.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-31-2008, 08:57 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
You can eliminate another home run by putting the kitchen lights on a circuit shared with another room, say a bedroom. Don't tap into the kitchen/dining room, laundry, or bath though.
Kyle
Old 02-04-2011, 10:29 AM   #7
RST
DIY Homeowner
Rewards Points: 150
A related question
Working on planning wiring in my kitchen and this thread is great! I have a related question. I have a trash compactor. The manual says to use a separate circuit, but the plate on the compactor says it draws something like 6 or 7 Amps. Right now it's combined with the built in microwave/range hood. Could I leave it like that? Could I combine it with the fridge instead (20A circuit)? Does it actually need a separate circuit?
RST
RST is offline   Reply With Quote
Old 02-04-2011, 06:52 PM   #8
Rewards Points: 79
Fridge
Refrridgerator needs its own circuit. The only other thing allowed on that circuit is a plug in clock (you see some of these recessed receptacles in older homes above the fridge).
CheapCharlie is offline   Reply With Quote
Old 02-04-2011, 07:03 PM   #9
Master Electrician
Rewards Points: 3,874
That is false.
brric is offline   Reply With Quote
Old 02-04-2011, 07:04 PM   #10
Rewards Points: 79
Originally Posted by brric View Post
That is false.
Not in Canada it isn't
Old 02-04-2011, 08:22 PM   #11
joed's Avatar
Rewards Points: 12,904
The OP needs to put this location into his profile so the proper codes can be quoted.
Old 02-04-2011, 08:25 PM   #12
So does CheapCharlie!
Old 02-04-2011, 09:06 PM   #13
Rewards Points: 282
To the OP: Check out Dave's sticky NEC- National Electric code 2008 . I think it will answer your questions with minimal confusion.
Jim F is offline   Reply With Quote
Old 02-04-2011, 11:30 PM   #14
What is funny about this whole debate I really think they need to go back over the amp draw a kitchen has (since I have done them). Even old fridges I have tested only pull 4 amps with the compressor running. The new micros pull about 8.5-9.6 amps (2005 till now new micros when installed). What I find even more funny about this is a home sump pump (watchdog-zoeller) pull almost 26 amps when they start up then drop down to about 13 running but only require a 15 amp circuit. So for your kitchen I would run it this way---
I run the receps- 20 amp with a GFCI breaker in the box.
The lights normally get split into 2 circuits--- (so if you blow a breaker you still have light)
Then micro -- 20 amp
dw/garbage-- 15 amp
fridge /ld undercab lights-- 15amp.
proremodel is offline   Reply With Quote
Old 02-05-2011, 06:56 AM   #15
The RED is mine:
Originally Posted by proremodel View Post
I run the receps- 20 amp with a GFCI breaker in the box. Waste of $$ IMO. GFI's at the device are also more convenient.
The lights normally get split into 2 circuits--- (so if you blow a breaker you still have light) Silly philosophy IMO. There is ALWAYS residual light, unless of course you are in a bathroom at night. How often does a lighting breaker trip anyway, ESPECIALLY a newly run circuit.
Then micro -- 20 amp Agreed
dw/garbage-- 15 amp Absolutely disagree. 20A circuit if they share a circuit.
fridge /ld undercab lights-- 15amp. Code violation. If you knew the code you'd have known this. Codes matter just as much as your "calculations".
Kitchen Wiring Plan - ok? Knucklez Electrical 19 07-14-2008 07:22 PM
wiring a kitchen pjm Electrical 23 04-15-2008 06:12 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 04:06 PM
Kitchen Vent Hood Requirements? 4everproject Appliances 1 02-03-2008 07:16 PM
