Kitchen Wiring Clarifications - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 12:21 PM   #1
Hello,
I am wiring my kitchen now, and have a few questions. Here is my current planned setup:
Circuit 1: Washer/Gas Dryer
Circuit 2: Refrigerator
Circuit 3: Dishwasher/Garbage Disposal
Circuit 4: Microwave and Gas Range
Circuit 5: Counter Top Outlets (3 of them)
I know that code says:
Kitchen counter top receptacles must be supplied by at least two small appliance branch circuits.
and
At least two 20-ampere branch circuits are required to feed receptacle outlets for small appliance loads, including refrigeration equipment in the kitchen, pantry, breakfast room, and dining room. These circuits, whether two or more are used, shall NOT supply anything other than receptacles in these areas. Lighting outlets and built-in appliances such as garbage disposals, hood fans, dishwashers, and trash compactors are NOT permitted on these circuits.
So my questions are:
Do I really need to run 2 circuits to supply my 3 counter top outlets?
Do I really need to run a separate circuit to supply counter top lighting, or is there a circuit there that I can supply it off of?
Thank you for your time and help.
-John
sullivja is offline   Reply With Quote
Old 07-19-2012, 12:26 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
Yes, you need 2 circuits, so I would feed the fridge and one receptacle with one circuit, and the other two with the second circuit.
Bring the lighting circuit from another room to hit both the overhead and undercabinet lights.
Old 07-19-2012, 12:27 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
#1 Yes...however, I doubt you are spacing your receptacles correctly. Max distance between countertop receptacles is 4'. Any counter 12" or more needs a receptacle...a receptacle is needed within 2' from any break in the counter.
I am not saying that it is not possible you only require 3 countertop receptacles, I am saying it would be rare that only 3 would be required.
#2 You do not need a separate circuit for countertop lighting, but you cannot use kitchen receptacle circuits for the lighting. You could use any other lighting circuit in the area to feed the countertop lighting/kitchen lighting.
Old 07-19-2012, 12:30 PM   #4
k_buz's Avatar
If you are installing a micro over the range, there is a good chance it is going to require at least a separate 15A circuit, probably separate 20A circuit in its specs. I would put the 120V range recept on with the counter outlets.
Old 07-19-2012, 12:35 PM   #5
Thank you for your quick response!
I live in a fairly small condo in Chicago, and my kitchen is set up like this:
24'' counter (outlet 1)
Stove
24'' counter (outlet 2)
36'' Sink Base
24'' counter (outlet 3)
Refrigerator
Washer Dryer
I have one outlet above each counter except the sink base. I guess the two outlets on either side of the sink are probably farther than 4' apart, but I figured with the sink in the middle I would be okay. Is this incorrect? If so, then how should I adjust it to meet the 4' requirement?
I don't have access to the electrical for the other lighting without pulling the ceiling down (or at least a lot more work). I do have a 3/4 inch pipe running to the circuit box on the wall though, so it would be easier to run a dedicated circuit for counter top lights than tap into the overhead lights... it just felt a little ridiculous.
Old 07-19-2012, 12:40 PM   #6
k_buz's Avatar
The sink does constitute a break in the counter. You would need a receptacle 2' from each side of the sink. Not one over the sink.
Then pull wires from the panel and you can pigtail to another circuit there. It will save you a couple bucks on a breaker.
Old 07-19-2012, 12:46 PM   #7
What do you mean pigtail to another circuit? Like the Garbage Disposal/Dishwasher circuit?
Old 07-19-2012, 12:48 PM   #8
k_buz's Avatar
No, another lighting/general purpose receptacle circuit...ie the living room or bedroom.
Old 07-19-2012, 12:59 PM   #9
If I wanted to hide the range outlet, am I allowed to use the countertop circuit to have an outlet that would be below countertop height?
This means that I do have the right number of outlets. Should I really give these 3 outlets 2 different circuits?
Also it is probably important to note, that the condo is about 100 years old, and for the entire rest of the 2 bed 1 bath condo I only have 3 circuits, and before I did the remodel, the entire kitchen was on 1 breaker.
Thanks again for all your help.
Old 07-19-2012, 01:05 PM   #10
k_buz's Avatar
Yes, there is no requirement that only kitchen counter receptacles can be on the 20A circuit.
Yes, to be code compliant, you need to have 2 20A circuits supplying the counter top recepts.
Old 07-19-2012, 02:02 PM   #11
Thanks for all your help. Last question:
Is it a problem sharing the Garbage Disposal and Dishwasher on the same 20amp circuit? I have seen opinions both ways, and see that my garbage disposal is 7.9amps. I found the 'minimum amperage' for the dishwasher at 9.1 amps, but can't find what the maximum should be.
Thoughts?
Old 07-19-2012, 02:07 PM   #12
k_buz's Avatar
According to the NEC you should be OK, but make sure to read the installation instructions of both the dishwasher and disposal as they might require one or both to be on their own circuit.
Old 07-19-2012, 02:10 PM   #13
I don't have the manuals, as they were already installed, but I will see if I can find them.
I just wanted to say thank you one more time. You answered the questions I have spent hours searching for answers to, and I feel far more confident moving forward. Thanks again and best wishes!
Old 07-19-2012, 03:44 PM   #14
Rewards Points: 344
You didn't mention it, but just in case if you have an island, it needs a receptacle as well.
herdfan is offline   Reply With Quote
Old 07-19-2012, 07:06 PM   #15
Rewards Points: 6,652
sullivaja, you have 4 circuits now. As long as they are 20 amp with #12, you are covered for the Kitchen.
The two circuits for the kitchen, can do counters, baseboards, pretty much the whole kitchen and dining. it is the min. required for a home prep/eating area.
Can't figure out kitchen light wiring... 19mquinn79 Electrical 9 09-23-2011 05:55 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 06:51 AM
Kitchen Wiring Requirements SS396 Electrical 24 02-07-2011 11:00 AM
Wiring inside kitchen island? vsheetz Electrical 14 05-12-2009 02:49 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 05:06 PM
