Kitchen Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 07:48 PM   #1
Rewards Points: 1,628
Kitchen under cabinet lights
I don't have the cabinets yet and need to figure out how to rough in a box for under cabinet lights.
First, is it OK to splice off a 20A circuit dedicated for the range hood to serve these under cabinet lights?
Second, where is the best position (height from floor) for the rough in box? Those are typically low voltage right? How are the wiring between those lights handled? Do you run them behind wall then out to the light and back into the wall...or are the wiring just concealed on the underside of the cabinets?
Thanks,
miamicuse is offline   Reply With Quote
Old 07-03-2013, 09:37 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The answer to your first question is....maybe. It would depend on if the hood is cord/plug connected.
The answer to your second question is again a little dependent on what you buy. I rarely installed low voltage undercabinet lighting...however, that was before LED's becoming more common place.
We stubbed out NM at about 56" and hardwired the fixtures tight to the wall. Be careful, not all low voltage wiring is rated to be concealed. When I did install a low voltage system, we ran NM up the wall and changed over to low volt cable in a tiny JBox where it come out of the wall.
Old 07-04-2013, 02:10 PM   #3
CitadelBlue's Avatar
Rewards Points: 97
Originally Posted by k_buz View Post
........................ When I did install a low voltage system, we ran NM up the wall and changed over to low volt cable in a tiny JBox where it come out of the wall.
Got a picture of this tiny JBox?
CitadelBlue is offline   Reply With Quote
How do you replace under cabinet lights with LED lights matte7 Electrical 1 09-08-2012 11:36 AM
Access through kitchen cabinet to pipes taylorroad Carpentry 4 09-01-2012 06:09 AM
Recessed Can Lights in Kitchen Remodel rjrivero Electrical 0 05-05-2011 06:28 PM
Recessed lights in kitchen - need advice rfranco1 Electrical 3 01-29-2011 07:29 PM
Kitchen Cabinet Toekick color cellophane Interior Decorating 3 10-29-2009 03:52 PM
