Kitchen Sink Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 11:09 AM   #1
As the title states I have a light over my kitchen sink. That light is controlled by a switch next to the sink, which shares a box with a countertop outlet. My question is, can the sink light pull power from the GFI protected outlet or should it be on the lighting circuit. I would think since I can reach it from the sink it should be protected..
Thanks in advance, Scott
SW315 is offline   Reply With Quote
Old 01-22-2012, 11:12 AM   #2
Rewards Points: 14,312
It should be on the lighting circut and it does not have to be GFI. Only the counter outlets need GFI.
Old 01-22-2012, 11:13 AM   #3
Julius793's Avatar
It can share if there are already 2 dedicated lines to the counter tops
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-22-2012, 11:14 AM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by SW315 View Post
...can the sink light pull power from the GFI protected outlet
Are you asking "best practices" or past/present code rules?
Old 01-22-2012, 11:16 AM   #5
Both..With you asking I would say code says no, but real world practice says its a good idea.
Old 01-22-2012, 11:55 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
By current Code, lighting cannot be on the circuits for kitchen receptacles (SABC’s). Small Appliance Branch Circuits are to serve receptacles in the kitchen, dining room, pantry, breakfast area, and the like, only. They shall have no other outlets. (A receptacle is not an outlet)
Kyle
Old 01-22-2012, 11:57 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
Deleted double post
Kyle
Old 01-23-2012, 05:22 PM   #8
Thanks for the replies!
Looking for a special light switch for task lighting shazapple Electrical 3 01-02-2012 09:39 PM
1 source 3 separate switches elchildress Electrical 3 12-31-2011 09:51 AM
Newbie - fixing a switch and adding a light telechick Electrical 3 09-14-2011 08:59 PM
Grabbing power from a light switch box RedBear Electrical 3 01-13-2010 01:28 PM
