Old 02-01-2013, 05:27 AM   #1
Thumbs up
Kitchen Reno
Does anyone know if simply switching off mains electricity at the switchboard allows me to safely remove the wiring from the back of the oven and the hob? I'm uncertain as to whether that is sufficient to isolate the unit.
Cheers
Darwin_Man
Darwin_Man is offline   Reply With Quote
Old 02-01-2013, 06:17 AM   #2
Super Moderator
Kitchen Reno
Is it safe to assume you are from the UK? An electrician will be along soon---Mike----
Old 02-01-2013, 08:15 AM   #3
Resi EC
Kitchen Reno
Turn off the mains, check with volt meter.
Gac66610 is offline   Reply With Quote
Old 02-01-2013, 08:52 AM   #4
joed's Avatar
Kitchen Reno
If after turning off the mains the oven and hob no longer function then it is should be safe to disconnect them.
Do not PM with questions that can be asked in a forum. I will not respond.
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 01:35 PM
Harwood in a Galley Kitchen Parallel to the Joists? David Osinga Flooring 8 12-05-2012 06:38 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 04:37 PM
My first kitchen reno....any tips? avro1 Remodeling 2 01-19-2010 10:49 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
