Kitchen Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 12:48 AM   #16
Rewards Points: 512
Originally Posted by k_buz View Post
If you used KB's idea, it wouldn't be wired like a 3 way switch, you would be using the switch in a different manner. That being said, I suggest running a new circuit.
If you were to use KB's idea, you would put the hot wire to the dishwasher on one traveler screw, and the hot wire to the disposal to the other traveler screw, and put the incoming hot to the common. But like he said, you would not be able to hardwire the appliances.
k_buz, tks for the reply. have I got this right?
12/3 between switch and receptacle; at switch:
R to top traveler (for Disposal)
B to bottom traveler (for DW)
W to W of 12/2 to panel
at receptacle:
B to bottom (for DW)
R to top (for Disposal)
W to neutral side
Break tab from Hot side of recep.
sirsparksalot is online now   Reply With Quote
Old 04-30-2012, 07:45 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That looks to be correct. You do realize that you will not be able to use the dishwasher and disposal at the same time...right? I think you are going to regret not running the separate circuit.
edit...if you are planning on running the separate circuit and I misunderstood, then you don't have to bother with the 3 way switch situation. Usually, a dishwasher and disposal can be on a 20A circuit together with no problem (check with the specs).
If you are planning on using the existing 15A circuit, you will not be able to use both the dishwasher and disposal at the same time.
The Following User Says Thank You to k_buz For This Useful Post:
sirsparksalot (04-30-2012)
Old 04-30-2012, 09:01 AM   #18
Rewards Points: 512
buz, thanks for clearing that up for me. There is no existing 15 amp circuit. I will install a new 20 amp circuit for DW and Disposal.
Old 04-30-2012, 09:12 AM   #19
Rewards Points: 6,652
sirsparksalot, if you are smart, you place the switch for the disposer & dw inside the door of the Sink base. I have done that with the last two disposalls that I have installed in places that I own, and works out great. No accidental trips.
Old 04-30-2012, 02:42 PM   #20
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by kbsparky View Post
It's real simple to use a 15 Amp circuit for both the disposal and dishwasher.
No need to worry about sizing the loads as described above IF you use a 3-way switch to control them both.
Here's how to do it:
Connect your incoming 15 amp line to the "common" terminal on the 3-way switch. Use a 14/3 cable to a split-wired receptacle under the sink.
Configure the switch so that when it is down, power goes to the dishwasher half of the outlet. When the switch is up, the dishwasher shuts off, and power goes to the disposal outlet.
The outlets serve as the required disconnects, so the switch is not required to have "on" and "off" marked on it.
This way, you have non-coincident loads and only have to size the circuit to the largest appliance. Very useful in existing installations.
I have actually suggested that in some of the inspector classes I have taught. It is not always well recieved. I suggest running it by the inspector before hand to avoid any potential problems. Also check the installation instructions for both appliances. Usually the higher end D/W's have a nameplate rating of 13.6A and need a 20A circuit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
sirsparksalot (05-01-2012)
Old 05-01-2012, 05:41 AM   #21
Electrical Contractor
kbsparky's Avatar
Originally Posted by electures View Post
...Usually the higher end D/W's have a nameplate rating of 13.6A and need a 20A circuit.
WHY would one need a 20A circuit to supply an appliance with a nameplate rating of 13.6A? I would think a 15A circuit should do the job ...
In cases where you are installing a new circuit, then sure: Put in a 20A! But my original assertion was to accommodate existing installations where you need to operate both the DW and disposal and only had a single 15A circuit to work with.
I never have understood why many think a dedicated circuit is needed for such an intermittent load as a garbage disposal unit. In many cases, it operates for maybe 30 seconds at most, just a couple of times a day.
-KB
Old 05-01-2012, 10:47 AM   #22
electures's Avatar
1. 80% of 15A is 12A.
2. The manufacturer may recommend a 20A circuit.
3. Adding a GD to the circuit may overload the circuit depending in the size of the disposal.
I also do not have a problem with supplying both a DW and GD from the same circuit as long as the circuit is of adequate size. Some posters here routinely make the blanket statement that is permitted without even knowing the ampacities of the appliances. I prefer the DW on its own circuit and supplying the GD from a general lighting circuit. But that's me. I also like the 3way idea.
Old 05-01-2012, 11:06 AM   #23
Must be a pretty large dispoall to overload the circuit. Majority that I have seen for residences, are lucky to be no more than 5 amps.
Old 05-01-2012, 11:27 AM   #24
i'm guessing that higher number includes an electric heating element.
itsnotrequired is offline   Reply With Quote
Old 05-01-2012, 12:46 PM   #25
electures's Avatar
From Insinkerators Website.
Namplate NEC Table 430.248
1/3HP - Nameplate 6.7 Amps, NEC 7.2 Amps
1/2HP - Nameplate 6.9 Amps, NEC 9.8 Amps
3/4HP - Nameplate 8.1 Amps, NEC 13.8 Amps
frenchelectrican (05-02-2012)
Old 05-01-2012, 12:49 PM   #26
electures's Avatar
For a disposal?
Old 05-01-2012, 01:24 PM   #27
For a disposal?
don't want anything cold down the drain!
didn't notice it was referencing the disposal. i was looking at the 13.6 amp requirement for the dishwasher.
Old 05-01-2012, 01:43 PM   #28
electures's Avatar
LOL
Old 05-01-2012, 05:34 PM   #29
Rewards Points: 214
For the life of me I cannot figure why the OP would ever consider this if he is going to be running a new circuit?
I really don't know why anyone would consider wiring the Disposal and Dishwasher in such a hokey wiring/three way switch scenario, minus having no other choice? Most dishwashers are digital today and if you get some kid constantly turning the Disposal on/off (while the dishwasher is trying to run) I can only see eventual damage resulting, IMHO.
Ralph
Ralph III is offline   Reply With Quote
Old 05-01-2012, 06:38 PM   #30
Ralph III, mine will go into "Purge" mode if it loses power. When I decide to finish my Kitchen, I am just running a separate circuit for the DW. I know that ours is around 13 amps when running in Sanitizer mode.
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 10:45 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
20Amp Kitchen Split / Dual outlets WaldenL Electrical 21 09-11-2009 04:09 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
