Kitchen Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 07:47 PM   #1
Rewards Points: 512
kitchen receptacles
New appliances coming in. No change in service, so I believe that existing wiring can be considered grandfathered. Please correct me if wrong. BTW: we're under 2005 code in my locality, but I go with 2008.
Currently, the kitchen is wired all 15-amp except for non-counter-top receptacles. (I know, opposite, and wrong, but that's the way it is)
  • Can dishwasher and disposal be on same 15 amp circuit? (This will be a new circuit, so perhaps I need to run 20-amp?)
  • Current range wiring is 3-wire on a 40 amp breaker (3-pole). Can I still utilize a 3-prong receptacle here?
  • Does the kitchen wiring have to be upgraded to provide for 2 SABC (currently, only 1), and 20 amp?
Old 04-29-2012, 07:52 PM   #2
for the first two items, what is the load rating of the appliances you are getting? do any of these appliances require dedicated circuits for warranty purposes? if the range is over 8.75 kw, breaker will need to be 40 amp minimum.
i don't believe the sabc circuits need to explicitly be updated per code but your municipality may require it.
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
electures (04-29-2012)
Old 04-29-2012, 08:59 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
GD and DW are permitted on the same circuit but, the circuit has to sized based on the size of the loads!!!!!!!!!!!!!!!!! And the manufactures installation instructions. Most DW manufactures recommend a seperate circuit. AS for the SABC's, they shouldn't have to upgraded unless you are remodelling the kitchen. Just because you bought new appliances doesn't mean you have to rewire the entire kitchen. However, if the manfacturer recommends certain wiring you should follow it for warrenty purposes. The NEC permits using the existing wiring as long as it is the correct size for the range, but again follow the installation instructions.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-29-2012, 09:24 PM   #4
Electrical Contractor
kbsparky's Avatar
It's real simple to use a 15 Amp circuit for both the disposal and dishwasher.
No need to worry about sizing the loads as described above IF you use a 3-way switch to control them both.
Here's how to do it:
Connect your incoming 15 amp line to the "common" terminal on the 3-way switch. Use a 14/3 cable to a split-wired receptacle under the sink.
Configure the switch so that when it is down, power goes to the dishwasher half of the outlet. When the switch is up, the dishwasher shuts off, and power goes to the disposal outlet.
The outlets serve as the required disconnects, so the switch is not required to have "on" and "off" marked on it.
This way, you have non-coincident loads and only have to size the circuit to the largest appliance. Very useful in existing installations.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
electures (04-30-2012), Evstarr (04-30-2012)
Old 04-29-2012, 09:26 PM   #5
Rewards Points: 512
Thank you, guys. Good and clear answers.
Old 04-29-2012, 09:27 PM   #6
Rewards Points: 512
ooh, kb, didn't see yours; reading now :-)
Old 04-29-2012, 09:34 PM   #7
Rewards Points: 512
Oh, that's very good. But, could this become confusing for the consumer if the DW is running, and they forget and turn on the disposal, the DW stops, or, in order to run the dishwasher, consumer must make sure the switch is down, AND they have to use the DW controls to start and stop? I assume, then, that normally "OFF" (nothing is running) would be down.
EDIT: I guess that's how it works in the real world anyway - lol. Is this a common practice lately?
Old 04-29-2012, 10:44 PM   #8
reminds me of my house in chicago, where the dishwasher disconnect was a wall switch in a two gang box that also include the overhead light switch. after three times turning the dishwasher off mid-cycle, i put a piece of tape over the dishwasher switch.
Old 04-29-2012, 11:12 PM   #9
Rewards Points: 512
now, I'm trying to figure out how kb's idea is wired. Is a 3-way really required, or can a single pole work the same?
Please tell me the connections for the red, white and black of the 3-wire to the receptacle.
EDIT: Do I need two 3-way's?
Old 04-29-2012, 11:36 PM   #10
Rewards Points: 214
If you're having to run a new circuit to the dishwasher and garbage disposal, why would you ever consider a 15amp circuit and a confounded 3 way switch? Just run a 20amp circuit, otherwise as manufacturer or local ordinance dictates, and call it a day.
Good luck
Ralph III is offline   Reply With Quote
Old 04-29-2012, 11:44 PM   #11
Rewards Points: 512
Sparky's idea intrigued me. And it doesn't have to be a 15 amp, I could run a 20. I just need directions to wire this. Are two 3-ways needed for this? I've looked at several diagrams, but can't find sparky's idea. Almost all of the diagrams show a single pole switch and a split receptacle, with just 2-wire cable (14-2, or 12-2).
Any of the other viewers out there?
Old 04-29-2012, 11:46 PM   #12
Rewards Points: 512
BTW, in trying to diagram this (using just one 3-way), I end up with no wire to connect to the second traveler on the S3.
Old 04-29-2012, 11:49 PM   #13
kevinp22's Avatar
I would agree with ralph on running the 20 amp circuit.
I asked alot of questions about this when I was doing my rewire.
Apparantly some inspections treat it differently than others -- I read responses from "doesnt care" to "had to treat dw as continuos load". you may want to search past threads on this sub topic.
Id check with your inspector, assuming of course you pulled a permit
I put both of mine on one 20A circuit without a funky switch but my appliances have low enough draw to be within the limit even treating the DW as a continuous load
kevinp22 is offline   Reply With Quote
Old 04-30-2012, 12:31 AM   #14
Rewards Points: 512
http://www.askmehelpdesk.com/electri...ch-386123.html
Is this how it works? I'd be using the power to switch first.
Old 04-30-2012, 12:34 AM   #15
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you used KB's idea, it wouldn't be wired like a 3 way switch, you would be using the switch in a different manner. That being said, I suggest running a new circuit.
If you were to use KB's idea, you would put the hot wire to the dishwasher on one traveler screw, and the hot wire to the disposal to the other traveler screw, and put the incoming hot to the common. But like he said, you would not be able to hardwire the appliances.
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 10:45 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
20Amp Kitchen Split / Dual outlets WaldenL Electrical 21 09-11-2009 04:09 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
