Kitchen Receptacle Spacing - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 06:10 PM   #16
Master Electrician
Rewards Points: 3,920
Originally Posted by joed View Post
If that is electric baseboard then you can not put a receptacle above it.
You are correct. Where do you see a recep above the baseboard?
brric is online now   Reply With Quote
Old 02-11-2011, 10:20 PM   #17
Rewards Points: 165
No, it is a cast iron convector; water not steam. I was planning on having an outlet on either side of the window that it is below. The window is 5' wide so that would fall within the 6' wall spacing rule. I think that I now have all the information I need for this. I will have two outlets per 50" counter and on the same circuit I will have two other wall outlets. The second circuit will be for the two outlets on the smaller counters on either side of the stove plus two more wall outlets. That will give me the two small appliance branch circuits required by code. They will be 20A circuits; GFCI protected. The stove will have a dedicated 15A circuit. The dishwasher will have a 20A dedicated GFCI circuit. The stove will have its own circuit as well. Thanks for all the help everyone!
chronojosh is online now   Reply With Quote
Old 06-27-2011, 05:43 PM   #18
how can I find out the minimum spacing for outlets in a kitchen, keeping in mind I am from Canada
jimmybuffett is offline   Reply With Quote
Old 06-27-2011, 05:55 PM   #19
Rewards Points: 6,652
How long is the counter top that you plan on putting the outlet on? It would be in the CEC regarding this. I live down North of you, and on my counter that is 36" long, there is one outlet in the middle, due to sink base to the left. If 48", two outlets is standard at around 24" apart. I have seen as far as 36-42 inches apart in some homes where I live that are Tract homes.
The Following User Says Thank You to gregzoll For This Useful Post:
jimmybuffett (06-27-2011)
Old 06-27-2011, 07:20 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Love the name, as I am a biggg fan!!!!!!!
Old 06-27-2011, 08:08 PM   #21
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Frig can be a 15 or 20A dedicated circuit without GFI protection.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-28-2011, 10:29 AM   #22
RST
DIY Homeowner
Rewards Points: 150
I think the spacing may be similar, but there are additional requirements regarding how you run cable and connect the receptacles. Hopefully a Canadian electrician will clarify further.
RST
RST is offline   Reply With Quote
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 10:07 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 02:39 PM
15A receptacle circuits in kitchen _in addition to_ 2x 20A? WaldenL Electrical 4 09-18-2009 04:58 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
