Kitchen Receptacle Spacing - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 08:24 PM   #1
Rewards Points: 165
Kitchen receptacle spacing
I am remodeling my kitchen and have the kitchen gutted to bare studs. I am starting to plan for the wiring but am having trouble with the NEC requirements for receptacle spacing. There is a 32" wide door at the start of one wall and then there will be an ~ 50" counter, then a 30" sink, then another ~ 50" counter. I understand the receptacles must be within 24" of the sink, but what about the door? Since the end of the counter is next to the door, do I put a receptacle within 24" of that or would one receptacle within 24" of the sink suffice on these counters?
chronojosh is online now   Reply With Quote
Old 02-10-2011, 09:20 PM   #2
joed's Avatar
Rewards Points: 11,576
You need one withing 24" of the end of the counter/ The 50" counters need two receptacles.
The Following User Says Thank You to joed For This Useful Post:
chronojosh (02-11-2011)
Old 02-10-2011, 10:16 PM   #3
Licensed electrician
Rewards Points: 1,024
There can be no more than 4' between the countertop receptacles. I would certainly put at least 2 receptacles per 50" countertop.
Old 02-10-2011, 10:40 PM   #4
joed's Avatar
If the counters were 2" shorter then one receptacle each would be all you need.
Old 02-10-2011, 11:13 PM   #5
Journeyman Wireman
Rewards Points: 150
Remember that the NEC is a minimum. First receptacle within 2' of edge of counter top, every 4' after. Start the count again when you have a break in the counter like a sink.
Wire for enough receptacles to meet your current (and future) appliance needs. That may be more than the minimum required.
Jupe Blue is offline   Reply With Quote
Old 02-10-2011, 11:51 PM   #6
Rewards Points: 6,652
To the right of my sink, I have one outlet that is centered. To the Left, is the Portable Dishwasher with the microwave on top, which was against the window, so of course I had to put a outlet there, which the Fridge was in that space before. So of course, I ended up with a lower outlet for the fridge on one circuit, and the upper on its own circuit. It meets the rule of two, because of the counter length. By my stove, only one, which is going to get moved once my wife figures out the cabinet & layout she wants, which so far has changed twice.
Remodels are great when you start them, but guaranteed, will change six to eight times, and Electric will change by a rule of three. That means for every layout change or flooring change, the Electric gets changed in the layout three times. I myself am only up to the Second time, and looking at one more by time for one wall, when all is said and done.
Do not get me started on my bath remodel. She wanted not one outlet on the right of the sink, but a second one to the left of the sink on the wall between the toilet & vanity cabinet. Her reasoning, was that she would have the night light on the wall outlet to the left of the sink and also plug in her Curling Iron in that outlet, but nothing ever gets plugged into the GFCI. Did I state that nothing ever gets plugged into the GFCI.
Old 02-11-2011, 06:50 AM   #7
Rewards Points: 165
Thanks for the replies, that clears that up. So two outlets per counter it is. I was looking at my plan again and have a new question. My kitchen is a galley style kitchen and my two small appliance branch circuits are going to serve the counter top outlets on each wall (One branch for one wall one for the other). My question is can these branches also serve a wall receptacle for their respective walls ? The NEC mentions something about this but I want to make sure that I am reading it right. I think as long as they are in the kitchen/dining area they are ok, and they can't be used for lighting if I am not mistaken. Thanks for the help again.
Old 02-11-2011, 08:47 AM   #8
joed's Avatar
If you mean a wall receptacle on the other side of the wall then not normally. If the other side is a dining room then they must be on the small applliance circuits. If not a dining room then it is not permitted.
Old 02-11-2011, 08:50 AM   #9
My counter with the kitchen sink is around 73" (36" sink base, 2 18" cabinets), so that is why I have only the one to the right of the sink, but when we moved the fridge, added the second to the left. Post a picture of the walls in question, and floor plan, so it can give everyone an idea where to go with helping you the best way.
See the graphic reagarding the SABC.
Old 02-11-2011, 10:00 AM   #10
Rewards Points: 165
The attachment is something I just drew up of my layout. Let me know if it doesn't open.
Also, do I need an outlet on the wall after the cabinet to the left of the sink ends? The space from there to the far left outlet is about 8ft. Sorry if the scale of the drawing is off a bit (or a lot!)
Old 02-11-2011, 11:44 AM   #11
RST
DIY Homeowner
Rewards Points: 150
Don't forget a receptacle for the fridge. It can be on a dedicated circuit or a SABC.
Are you saying the distance from the counter to the far left outlet is 8'? If so, I think you need another outlet on there somewhere because a receptacle must be within 6' of any point of an uninterrupted wall segment. I don't think you can count the countertop receptacle toward that 6', but I could be wrong on that. In my layman's opinion I think you are OK otherwise.
RST
P.S. If you are in Canada the rules for countertop receptacles are different than in the U.S. Not sure where you are.
RST is offline   Reply With Quote
Old 02-11-2011, 12:21 PM   #12
Rewards Points: 324
RST
the 6' rule is for wall spaces not assoated with counter spaces.as in livingrooms,bed rooms.
oleguy74 is online now   Reply With Quote
Old 02-11-2011, 12:23 PM   #13
Rewards Points: 165
Yes, that is what I meant. I guess I'll have to add another outlet to that wall. I am planning on a dedicated receptacle for the fridge and one for the dishwasher as well. I was just looking for info on the ones that I have shown. Still not sure about whether or not the wall receptacles can be on the same circuit as their same colored (in the drawing) counter top receptacles. Thanks again.
Old 02-11-2011, 12:31 PM   #14
Master Electrician
Rewards Points: 3,678
Yes, the additional receps may be on the SABCs.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 02-11-2011, 06:31 PM   #15
joed's Avatar
If that is electric baseboard then you can not put a receptacle above it.
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 11:07 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
15A receptacle circuits in kitchen _in addition to_ 2x 20A? WaldenL Electrical 4 09-18-2009 05:58 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
