Kitchen Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 08:10 AM   #1
Kitchen Question
i was wondering. for a kitchen what is the code for fridge, garbage disposal, dishwasher, mircowave?
I know that i need outlets every 2 ft in the counter area (first one gfci, 20amp)
But what about for the other appliances? i know fridge should be a 20a. Can i group the the dishwasher and garbage disposal on 1 circuit (20a)? i know microwave should also have a dedicated 20a also.
baum is offline   Reply With Quote
Old 03-10-2010, 08:15 AM   #2
Just call me Andrew
Rewards Points: 1,020
You need 2 dedicated circuits w/ 20-Amp GFCI's for your kitchen counter.
I do believe the Dishwasher and disposal can be together.
Check out this thread:
Number of circuits needed for a small kitchen? All responses welcome!
Andrew
secutanudu is offline   Reply With Quote
Old 03-10-2010, 08:45 AM   #3
Kitchen is very "involved"
(2) 20a GFCI circuits for countertop, no lights (even under cabinte) !!
Fridge can be on one of these, but I ran a dedicated 15a circuit w/#12 wire for my fridge
I will actually have 3 or 4 20a counter top circuits
Dishwasher requires a "dedicated" circuit...many pull 12a, but disposal can be run off this circuit
What kind of Microwave ? Counter top does not need another circuit
But mine pulls 1100w so one reason I am running a 3rd 20a circuit
Many Mfgs require a dedicated circuit (over stove)
If you have a hood that plugs in over the stove they now require a dedicated circuit. Not sure why...smaller fans only pull 3a. This seems to be due to large fan systems for gas stoves & due to combo microwaves/fans
Code seems to indicate a dedicated circuit for over the stove Microwave if it exceeds 50% of the circuit, but wording seems to indicate lights allowed ?
I don't think the code is very clear on this, I've read the different sections multiple times & different people give different views
If it pulls 1200w or more I'd run a seperate circuit for the MW, some pull up to 1800w
Bottom line your local Inspector/code may require a seperate circuit
So you need to verify what your local code requires & what the Mfg requires
My toaster pulls 850w, my small toaster oven pulls ~1500w
Add another device you want to use at the same time & you can see why 3 20a circuits is a good idea
Old 03-10-2010, 08:48 AM   #4
Just call me Andrew
For the life of me I could not find that picture, Dave!
Andrew
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
Kitchen counter question axlmayhem General DIY Discussions 5 10-20-2008 09:32 AM
Kitchen walkway Design question dustandtools Building & Construction 1 10-14-2008 11:02 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
