Old 04-26-2009, 03:13 AM   #1
Send a message via AIM to theatretch85
Kitchen Peninsula
I am building a peninsula in my kitchen that will be approximately 5-6ft long and roughly 30 inches deep connecting into a post that makes up the corner of the kitchen/dining room/living room.
Code:
NEC 210.52 A receptacle outlet shall be installed at each counter space 12
inch or wider, and at each island counter or peninsular space 24 inch by 12
inch or greater. Receptacles shall be located not more than 20 inch above the
countertop, or where mounted below a countertop less than 6 inches beyond
the support base, not more than 12 inch below the countertop.
Code:
NEC 210.52 At kitchen countertops, receptacle outlets shall be installed so
that no point along the wall line is more than 24 inch measured horizontally
from a receptacle outlet in that space. Countertop spaces separated by range
tops, sinks or refrigerators are separate spaces.
Am I required to have outlets every 2ft on the peninsula or is one at the post ok? Am I going to need to install one on the end of the peninsula (I assume that I will be required to) and what is usually the best way to wire an outlet in a cabinet/counter-top peninsula? Just sleeve romex through flex conduit or sealtite?
I have a standard single gang plastic box mounted in the post for the outlet above the counter space, am I going to have to put in a metal box to transition to the BX to run through the peninsula? I can take some pictures if necessary to understand what I am talking about....
theatretch85 is offline   Reply With Quote
Old 04-26-2009, 07:58 AM   #2
Remodeling Contractor
Kitchen Peninsula
Run the wire through the back of the cabinets and install an outlet in the end cabinet below the counter top as long as the overhang is not excessive.
Old 04-26-2009, 08:52 AM   #3
Kitchen Peninsula
One outlet is required, but for an island that large, I would consider an outlet on each end, as Bob suggested. These must be part of the countertop circuits, or a separate 20A circuit.
Old 04-26-2009, 12:30 PM   #4
Kitchen Peninsula
Awesome, so I don't need one every 2 feet on the peninsula. What's the best/preferred way to run the power through the cabinet to the outlet on the end?
Old 04-26-2009, 12:31 PM   #5
Kitchen Peninsula
Use 12/2 AC cable along the back top edge.
Old 04-26-2009, 12:34 PM   #6
Kitchen Peninsula
Won't I need a metal box on either end to properly terminate that?
Old 04-26-2009, 02:08 PM   #7
Licensed Pro
Kitchen Peninsula
I would run NM along the back top edge. In that position, it is pretty well protected from physical damage.
Old 04-26-2009, 02:31 PM   #8
Electrical Apprentice
Kitchen Peninsula
This is where you have to start reading between the lines of the code book(the canadian one is the same way) It says any point on the counter has to be within 24" of a plug. Imagine a point with a plug 24" to the left and 24" to right you are meeting the code. This puts your plugs 48" apart and not 24".
I am in agreement with everyone else, put a plug on each end of the counter.
darren is offline   Reply With Quote
Old 04-26-2009, 03:10 PM   #9
Kitchen Peninsula
Yes, but you asked the best way. AC is flexible and offers more protection from a loose fork or knife in one of the drawers. But you can use Rmx since you have plastic boxes now.
More On This Topic
I’m Lee. I have a degree in architecture and about ten years in the construction field and today we’re doing a fairly ornate countertop in my own house. Both of the countertops are using the basic same colors, but it’s a different tile... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in the construction field and we’re laying out a diagonal countertop today. We have about the same spacing on both sides of the sink, and we’re going to start from... Read More »
People enjoy cooking on barbecues, but often get frustrated with the lack of space to work with. Building a counter around your barbecue adds space to set food, dishes, drinks and other items you need. You can also incorporate useful additions like... Read More »
Now we’re going to talk a little bit about the recycled products. The terrazzo type countertop material is usually a ¼ inch, you can even order it thicker than the ¼ inch, ½ inch, and it does have to have underlayment so it doesn... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. One choice you need to make when you are planning is whether you are going... Read More »
Microwave under counter in kitchen peninsula... Jeremy Hillary Boob, PhD Electrical 3 04-27-2009 05:37 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 10:31 PM
Installing receptacles in kitchen base cabinets shtoink Electrical 13 10-15-2008 09:52 PM
Idea for kitchen peninsula acomiskey Remodeling 3 05-17-2008 04:12 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-19-2006 12:23 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
