Kitchen Overload? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2005, 12:29 AM   #1
Post
Kitchen Overload?
Forgive me if I don't use the correct terminology but I'm a novice. I live in a co-op apartment and my circuit breaker box says it can hold 80 amps total. There are 2 outlets in the kitchen that share a 20 amp circuit. There is also a dedicated 20 amp line for a dishwasher. All the lines are 120V. The previous owners had a fridge, microwave, dishwasher and gas range. I am replacing all the appliances and getting an electric cooktop and seperate wall oven. I need a dedicated 220V, 20amp line for the electric cooktop which an electrician said would not be a problem. I also want an electric wall oven which would require another 220V 20amp line. Would I be in danger of overloading the circuits? My gut tells me to get a gas wall oven to be on the safe side. Any comments?
christinalee is offline   Reply With Quote
Old 11-29-2005, 06:04 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
The fixed appliances MUST be on thier own circuits. They CANNOT share the receptacle circuits. Nothing can.
Only kitchen receptacles can be on kitchen recepacle circuits.
Old 11-29-2005, 08:15 AM   #3
Have your electrician do a load calculation and or you could do one yourself. There are a couple of places on line that will step you through it.The code figures that not all appliances will be used at the same time so some items get downrated when figuring load calc. I'm guessing you'll be fine if you don't have anything else like clothes dryer or electric heat on the panel but check with your electrician. HS.
K2eoj is offline   Reply With Quote
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 09:45 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 07:17 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 07:13 PM
