Old 12-14-2011, 07:06 PM   #1
Limited Experience
Kitchen Outlet Question
Updating our galley kitchen. One side is shorter than the other by 2' to enclose HVAC ducting. This short wall has no outlets on it. Counter tops have outlets on both sides of kitchen.
Currently outlets for counter tops are wired in with other rooms. I'm changing them to be on their own 20A circuits. One circuit for each side of the kitchen.
Question. Assuming the above change is correct do I need to put an outlet on the 2' wall?
And if I have to have such an outlet or just decide to put one on this wall, can it be shared with the counter top outlets on that side? If not can it be shared with other outlets in the next room? Or must it have a dedicated breaker?
raleighthings is offline   Reply With Quote
Old 12-14-2011, 07:13 PM   #2
Licensed electrician
Receptacles in the kitchen and dining room can be on the 20 amp small appliance circuits.
Any countertop 12" or wider requires a receptacle. Longer countertops reire that no space be more than 2' from a receptacle.
Old 12-14-2011, 07:13 PM   #3
They must be 20 amp GFI protected and are suppot to be no more then 4' apart, non within reach of the sink.
And yes it would be best if all of them were on the same circut.
The ref. and micro wave should be on there on circut and never have a ref. pluged into a GFI.
Old 12-14-2011, 07:14 PM   #4
The receptacles can be within reach of the sink under the NEC.
Old 12-14-2011, 07:30 PM   #5
Limited Experience
Kitchen is short enough that no counter top is longer than 3'.
The side of the kitchen in question has in order:
36" counter top with outlet.
30" range space
Plenum space with 23.5" wall after drywall put in place.
The counter top outlets will be on a dedicated circuit.
Do I need an outlet on this short wall? There is none now. And if so can it be on the same circuit as the counter top outlets.
I think I'm fine on other side of kitchen.
24" counter top with outlet.
24" sink w/disposal.
24" counter top with outlet over dishwasher space.
Fridge space.
These outlets will be on dedicated circuit. Ditto Dishwasher, disposal, and fridge.
Old 12-14-2011, 07:31 PM   #6
Limited Experience
Oh, yeah. Replacing outlets with GFIC.
Old 12-14-2011, 07:35 PM   #7
You only need one GFI if all the effected outlets are on the same circut.
Old 12-14-2011, 07:37 PM   #8
Would you like to explain why you feel this way? Refrigerators should have no issue being on a GFI protected circuit. They are required to be GFI protected in a commercial kitchen.
Old 12-15-2011, 09:39 AM   #9
Limited Experience
Hmm. Galley opens on one end to dining room. Other end to what we call breakfast room. Fancy vs. day to day eating. Does this breakfast room count as a "dining" room?
Old 12-15-2011, 11:55 AM   #10
Limited Experience
And to ask again. Does my 23.5 inch wall require an outlet per latest national codes?
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 06:51 AM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 09:51 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
Question on GFI outlet HDoc Electrical 3 09-18-2006 10:38 PM
