Old 02-28-2007, 01:30 PM   #1
Kitchen outlet breaker
My coffee maker broke the outlet breaker. I reset it and then plugged the coffee maker into a non outlet breaker which broke the outlet breaker. Now I realize the none breaker outlets in my kitchen do not work. I have reset the main breaker. I sense I blew out the main breaker. Any thoughts?
simma is offline   Reply With Quote
Old 02-28-2007, 02:13 PM   #2
Nevermind I found another outlet with a break behind some stuff that needed to be reset.
Old 02-28-2007, 03:33 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Simma,
I'm not a pro electrician, but modern code requires Ground Fault Circuit Interrupter circuits in kitchens, baths, outside, etc. now.
Installing a GFCI receptacle as the first outlet in a circuit will make the rest of the non-GFCI receptacles beyond it in that same circuit to be GFCI protected, which is apparently what you have. You should test and reset it on a regular basis. Replace the GFCI outlet if it ever begins to fail to trip when tested.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-28-2007, 06:50 PM   #4
Thanks Mike. I realized there was another grounded outlet that broke and wasn't reset. All outlets work now
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
kitchen Island outlet richardremodeler Electrical 8 06-05-2007 06:45 PM
GFCI outlet vs. breaker - GF trip speed LanterDan Electrical 2 01-09-2007 07:05 AM
kitchen outlet no power apt238 Electrical 27 08-25-2006 08:37 AM
Define Split Outlet And Why Needed In Kitchen bobo Electrical 6 10-18-2005 11:35 AM
