Kitchen Lights Have No Breaker! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 05:56 PM   #1
Rewards Points: 1,062
Kitchen lights have no breaker!
LOL....I tried every breaker in the box, even the range/air handler one. (would 3 lights , 110v, be wired off a 220 circuit? I doubt it, right? 220 is not 100, period. ) I dont know what else to "switch"...LOL No other 110 v breakers in the box!
Any advice appreciated!
Pip
noquacks is offline   Reply With Quote
Old 11-01-2010, 06:05 PM   #2
joed's Avatar
Rewards Points: 11,598
Switch them all off. Then turn them on one at a time to see which ones turn on the light power. It could be that somehow two circuits are tied together and you need to turn off two breakers to kill power. This is not correct but it does happen.
Do not disregard the 240 volt double pole breakers. Who knows what the previous guy did.
Old 11-01-2010, 06:06 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it could be on a double pole breaker. If there is a MWBC feeding the two circuits required for the kitchen, the installer may have (should have) used a double pole breaker.
Old 11-01-2010, 06:07 PM   #4
dSilanskas's Avatar
If it's a multi wire circuit it has to be a double pole breaker....
dSilanskas is offline   Reply With Quote
Old 11-01-2010, 06:16 PM   #5
I could always depend on you guys!! Thanks! Time to go out there and switch buttons......
Old 11-01-2010, 06:17 PM   #6
Rewards Points: 1,214
Pip
Check the bulb.
COLDIRON is offline   Reply With Quote
Old 11-01-2010, 07:24 PM   #7
nap
You talking to me?
nap's Avatar
supposed to be.
Old 11-01-2010, 07:26 PM   #8
Originally Posted by COLDIRON View Post
Check the bulb.
Lights are ON. Then I go to the box and shut off breakers to see when lights go OFF.
Old 11-01-2010, 07:31 PM   #9
OK, curious: Too late for tonight.....got sidetracked, and now its dark, and box is outside. Black widows come out at night, and dont want to take chances (yup, theyre all over here (no bites in 12 years). .
So, tomorrow, when I do as you say to turn off all breakers, then turn on one at a time, how will I know which 2 are the ones? I mean, a combination of say, 2 breakers is what it takes, which 2 will be the ones if when I turn on the second one of the 2 I wont know which OTHER one is the second one. Say, I turn on 6, and the one that is the "dipole" one is say, 3 breakers away?? One has to do combinations, right? That could take an hour to do, eh?
Thanks!
Old 11-01-2010, 07:47 PM   #10
dSilanskas's Avatar
Originally Posted by nap View Post
supposed to be.
Has to be
Old 11-01-2010, 07:57 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
Thanks!
After you turn each breaker on, check the lights, then turn the breaker off again.
Old 11-01-2010, 08:12 PM   #12
nap
You talking to me?
nap's Avatar
Has to be
has to be= cannot be any other way
supposed to= by some applicable rule, it shall have a 2 pole breaker.
the circuits will function just fine with 2 single pole breakers so no, you don't have to. Code requires it but unless there is a person standing there with you every time you install breakers in your panel, it will always be "supposed to" cuz the guy that doesn't know surely can put in 2 single pole breakers.
Old 11-01-2010, 08:12 PM   #13
joed's Avatar
Thanks!
You won't need two breakers turned on to get lights or turning them off one at a time would have killed the power. However two separate breakers might turn on the lights.
Old 11-02-2010, 02:51 PM   #14
Thanks, Joed, so in conclusion, to do work safely on that circuit and have "power" off, do I need to have BOTH breakers identified/shut off or just one of them?
Old 11-02-2010, 03:04 PM   #15
Just call me Andrew
Rewards Points: 1,020
supposed to be.
Has to be
How about two single-pole breakers with a handle tie?
Andrew
secutanudu is offline   Reply With Quote
Circuit breaker popped and it is only connected to ceiling lights lisao Electrical 1 10-05-2010 09:34 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Outdoor lights on Kitchen Light Circuit WaldenL Electrical 5 08-28-2009 02:16 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
