Kitchen Lighting - How Many For My Kitchen - Thoughts? Ideas? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 08:25 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Originally Posted by CopperClad View Post
So would keeping the lights 1' away from the upper cabinets be ideal?
It also depends on the cabinet doors and if the cabinets are mounted flush to the ceiling.
I always use 2' because that is the depth of the countertop.
Old 06-25-2012, 09:44 AM   #17
Straying away from the halogens though. Same concept for LED's?
CopperClad is offline   Reply With Quote
Old 06-25-2012, 09:48 AM   #18
So If you have a soffit that the upper cabinets attach to , versus cabinets that are 1' down from the ceiling , you would lay out the lights different for each?
Old 06-25-2012, 10:37 AM   #19
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 520
By far, the trims and how far you recess the lamp in the fixture will have more effect on illumination than the diameter of the cans.
I recently installed (6) 4" cans in the center of my kitchen ceiling. I used silver specular trims in them. When I turn on all (10) 6" cans (the ones with black baffles and lamps recessed all the way and 65W lamps) they cannot even come close to the illumination put out by the (6) 4" cans that have 50W lamps. My cabinets doors are a creme color and reflect some of the light from the soffit cans but even that doesn't matter all that much.
The OP said
... I think I will stick with the 6" - also they are already nailed into place!
so the size is no longer an issue, only the spacing and placement.
Can lighting to me is more of an aesthetic thing than an illumination thing. They can add mood, highlight certain things and with all the trim options cast light in a number of different ways. That's why I like them and that's how I use them.
I have 53 cans in my house and only the ones closely spaced and centered on counters offer light usable for reading and things like that. Everywhere else, I have added other lighting to enhance the illumination.
On the homes I have done the design, I do the same thing and I let the homeowner know why. I've never had a disappointed customer.
JulieMor is offline   Reply With Quote
Old 06-25-2012, 11:49 AM   #20
Sorry, I guess what I was doing is what I've seen people on here refer to as "thread jacking." I was asking for my own knowledge. I am in the design phase of my mothers kitchen and she will be putting LED recessed fixtures in. So I'm just gathering information from various sources and making a decision based upon such found results.
Old 06-25-2012, 12:35 PM   #21
" Euro " electrician
frenchelectrican's Avatar
With LED verison is this will be a screw in type or a hardwired type ?
There are couple differnet type of LED luminaire et bulbs that can be used however before you start to go with LED route there is other item you need to check if you plan to use the dimmer down the road make sure they are dimable type some case they will mention specfic dimmer to use.
I have installed couple LED recessed cans they are not too bad the brand name is CREE I know they cost more than other brand but one nice big plus with CREE is they did come with frosted lens so you will not get such a glare as some of the convental LED even indenscent bulbs are.
As I will mention above the type I used is European specs so the Americian specs will be little diffent but wattage IIRC they are the same. ( due I do live in France )
Merci,
Marc
New house, need kitchen ideas wolfsburged Kitchen & Bath Remodeling 4 09-01-2011 04:09 PM
Need ideas for 1978 era kitchen makeover bookworm General DIY Discussions 9 08-22-2011 11:37 AM
Kitchen cabinet lighting options... bcbud3 Electrical 9 04-30-2010 10:03 AM
Looking for creative lighting ideas mwalt Electrical 2 04-17-2009 07:11 PM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 11:50 AM
