Kitchen Light Switch Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 01:52 PM   #1
Dear DIY community,
Recently bought a house, everything worked great. Yesterday the fiance was in the kitchen and complained that one of the lights (three separate single bulb lights on the same switch that hang over our island) stopped working.
Had worked fine earlier in the day.
Checked the breaker, nothing tripped. This light is on a 3 gang switch plate with two other light fixtures elsewhere in the room which were and are still working fine. Checked the 3 bulbs in another fixture, all fine. Got my voltage tester out and checked the switch for the effected light, both the traveler (1 of 2) and the common have power when switch is on. The other traveler (2 of 2) and the common have power when the switch is OFF. They're never all on together. Light still doesn't work.
Replaced the switch. Problem persists. Thoughts? Thanks!
VAGuy is offline   Reply With Quote
Old 06-24-2012, 03:03 PM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 516
Remove the bulbs and check for voltage in the lamp socket.
JulieMor is offline   Reply With Quote
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Kitchen Sink Light Switch SW315 Electrical 7 01-23-2012 05:22 PM
Light will now switch off Manjo62 Electrical 3 02-10-2011 11:59 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
