Kitchen Light Fixture Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2007, 09:54 AM   #1
Kitchen light fixture stopped working
I have a hanging light fixture over my kitchen sink and it operates on a dimmer (rolling knob type). I cleaned the glass fixture and wiped down the rest of the fixture. Later that day, it failed to turn on. I checked the breaker and replaced the bulb. The fixture is about 15 years old and not sure of the age of the dimmer, but at least 15 years old too.
Please describe the steps to troubleshoot this. I have limited tools.
dlpcpa is offline   Reply With Quote
Old 12-17-2007, 12:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
The first step is make sure you used a good bulb.
Next it make sure you have power at the dimmer, then the top of the light fixture.
These test will require the power to be on, so be carefull!
jbfan is online now   Reply With Quote
Old 12-17-2007, 12:45 PM   #3
Did you loosen any wires when you wiped it down?
redline is offline   Reply With Quote
Old 12-17-2007, 01:36 PM   #4
waiting for spring
arichard21's Avatar
Rewards Points: 150
could it be on a gfi and when it was wiped down a little excess water from the sponge got to something and tripped the gfi?
arichard21 is offline   Reply With Quote
Old 12-17-2007, 08:46 PM   #5
Union Electrician
goose134's Avatar
seriously, check the bulb. Replace it with one you have SEEN working. You'd be amazed by the power of coincidental bad luck.
goose134 is offline   Reply With Quote
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Light Stopped Working gershon Electrical 5 01-10-2007 09:03 PM
