Kitchen Light/ceiling Fan Has Stopped Working? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 01:31 PM   #1
DIYFrau
glamgirrl's Avatar
Kitchen light/ceiling fan has stopped working?
My light/ceiling fan in the kitchen has suddenly stopped working. It's not the breaker, as all other lights on that breaker are fine. It's not the bulb, since the fan doesn't turn either, and It's not the connections- I took it apart to check them all, and they are fine.
So...what the heck could it be? I'm stumped, and I'm usually pretty good at fixing stuff.
What else can I do? Any ideas, please?
Thanks,
Cheryl
glamgirrl is offline   Reply With Quote
Old 07-10-2011, 02:24 PM   #2
Rewards Points: 6,652
Light switch, someone wired it on a GFCI outlet possibly. Get a no touch tester to check for voltage at the switch, junction box. Light switches do go bad. If the fan has a remote on it, check that out also.
Old 07-10-2011, 02:25 PM   #3
Master Electrician
Rewards Points: 3,698
Thanks,
Cheryl
Pull the chains?
brric is online now   Reply With Quote
Old 07-10-2011, 03:54 PM   #4
Rewards Points: 506
Did you check the connections in the light kit assembly, as opposed to at the ceiling?
Old 07-11-2011, 06:41 PM   #5
DIYFrau
glamgirrl's Avatar
Still broken, but here's what it's not...
Ok..so I borrowed a voltage tester, and checked the switch. I actually changed it for a new one, just in case. (My house is 1940's, with some updated wiring)
I'm getting power on the 2 black wires connected on the left, according to the tester, but nothing on the one red wire on the right. Is that normal? I always thought red was the 'hot' one, but perhaps not in this case?
The other switches on this breaker are fine, as are the ceiling connections. Somebody mentioned 'light box connections', but I don't know what they mean? the only connections I can see on the fixture are the ones at the ceiling.
Any more ideas? I really don't want to have to call an electrician for this. (especially since I live in a rual area, and there's only one guy, so he's pricey!)
Thanks,
Cheryl
Old 07-11-2011, 09:31 PM   #6
DIYFrau
glamgirrl's Avatar
Used the voltage tester on the wires at the fan..the red one isn't getting any power, even when the switch is on. The red one does have power at the switch though, when it's on. What does this mean? It's a pretty heavy copper wire, seems like it would be hard to break, and there's nothing int he attic to affect it. ???
Tags
ceiling fan , light fixture
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
whirpool refrigerator ice make stopped working neadhelp Appliances 2 07-24-2010 12:10 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
Outside outlet stopped working mclontz Electrical 13 12-11-2008 10:37 AM
