-   -   kitchen island outlet wiring problem (http://www.diychatroom.com/f18/kitchen-island-outlet-wiring-problem-117965/)
colarama 09-21-2011 11:09 PM
I'm upgrading out kitchen island.
The previous owner had created an island by taking a freestanding stove to which he then added a 15" base cabinet to each side and then put a big sheet of particleboard across the back tying the whole thing together. He then used a wall-mount range hood and jury-rigged an island hood by sticking particleboard to the back of it, and venting it right into the attic.
I took out the stove and cabinets, leaving a single conduit sticking out of the concrete floor with an old three-prong 240 hookup.
What I want to do is to build a new island out of base cabinets, 48" deep by 5' wide, with a cooktop. Hardwiring the cooktop to the old three wire seems straightforward, and I'm pretty sure I'm not violating code to do it, but a friend pointed out that there's probably supposed to be some normal electrical outlets.
I did some digging around and it looks like my code says an island needs at least one outlet. I can't run anything through the floor, and dropping down a post from the ceiling would really ruin the look of the kitchen. Are their any alternatives, like a legal way to tap into the appliance circuit? It makes me cringe even suggesting it, but then I stop to think that many standalone stoves have appliance outlets built into them...
colarama 09-21-2011 11:16 PM
Would it be possible to do a sub-panel inside a cabinet? then split off the appliance and the (GFI'ed) outlets?
kbsparky 09-21-2011 11:30 PM
Where does that conduit in the floor go? You might be able to pull in some additional wires to provide power for your counter top outlets ...
rjniles 09-22-2011 06:51 AM
To make a 120/240 volt sub panel, you need a 4 wire feed. If the existing wiring is 3 insulated conductors and the conduit is metal, it may be possible.
