Kitchen GFI - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 09:35 AM   #1
Rewards Points: 16
Kitchen GFI
After reading another post about the fridge tripping the GFI I have a question about something i've read before. I have read that the fridge can trip the GFI and when you run a kitchen GFI you should run the home run to the fridge first and then to the other outlets. Also have read that the fridge doesn't need to be GFI protected and you should put the GFI in the next outlet after the fridge? Is this true that the fridge doesn't need to be GFI protected? Thanks
ponch37300 is offline   Reply With Quote
Old 02-03-2009, 12:33 PM   #2
Electrical Contractor
According to 210.8 (A)(6) only countertop (small appliance) receptacles need to be GFCI, and, any receptacle within 6 feet of a sink.
There may be local codes that may require others to be GFCI.
hpp58 is offline   Reply With Quote
Old 02-03-2009, 12:38 PM   #3
In residential, yes
In commercial applications (restaurants) , all 120V kitchen receps must be protected.
220/221 is offline   Reply With Quote
Old 02-03-2009, 12:46 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Agreed not required to be gfci. This of course will depend on if your using a gfci breaker that protects the entire branch circuit or point of use gfci like a receptacle. If gfci breaker then you would need to use the exception that allows a dedicated 15 or 20 amp branch circuit for the refrigerator.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-03-2009, 12:55 PM   #5
I ran a dedicated circuit for my fridge, 12g wire - 15a breaker
I don't want to risk having the breaker kick due to an appliance plugged in on the small appliance circuit
Old 02-03-2009, 12:57 PM   #6
DIYer
12g wire - 15a breaker? You have a lot of 12 laying around or something?
Gigs is offline   Reply With Quote
Old 02-03-2009, 01:14 PM   #7
Hey, it never hurts to oversize wire. It's like spraying teflon on those electrons.
Old 02-03-2009, 01:52 PM   #8
Yes actually I do
I installed it as it was a fairly short run
And just in case the wife decided she wanted a huge fridge that needed more power. I kinda think that a 26 cu ft fridge is big, but the wife gets what the wife wants in regards to the kitchen
I also ran 12g wire to the AC on the 1st & 2nd floors, also fed with a 15a breaker. Again just in case we decide to install bigger AC. That would be my decision - I hate sleeping on hot weather
Cheap temporary kitchen flooring idea. ember64209 Flooring 9 01-10-2009 12:45 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
