Kitchen Gfi - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 12:47 PM   #1
kitchen gfi
I have a kitchen gfi and the red light is on and you can not plug anything in or reset it. It looks like someone stuffed plastic into every hole like the windows closed on it ? What do I do? Thanks
knitknit2 is offline   Reply With Quote
Old 03-13-2012, 12:51 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Sounds like a tamper resistant GFCI that has something wrong with it.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-13-2012, 01:56 PM   #3
Rewards Points: 242
As far as the plastic goes...sometimes that's just the child protective option that some outlets have. Maybe not in your case. Picture please.
Always consider this, you may have something tripping the GFCI outlet...and that may be why is isn't resetting.
The red light may be on because you have a fault down line. This GFI/GFCI may be protecting more outlets than just itself.
Ed911 is offline   Reply With Quote
Old 03-14-2012, 08:20 AM   #4
Rewards Points: 3,130
I think some GFCIs have a red light that will come on if the receptacle isn't wired correctly. Don't know about the plastic - TR receptacles aren't required here so I've never even seen one.
Old 03-14-2012, 08:41 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Tamper resistant receptacles are required by the 2008 NEC code cycle and WV is on 2008.
What are tamper-resistant electrical receptacles and what is the new requirement?
The 2008 National Electrical Code®(NEC®) will require new and renovated dwellings to have tamper-resistant (TR) receptacles. These receptacles have spring-loaded shutters that close off the contact openings, or slots, of the receptacles. When a plug is inserted into the receptacle, both springs are compressed and the shutters then open, allowing for the metal prongs to make contact to create an electrical circuit. Because both springs must be compressed at the same time, the shutters do not open when a child attempts to insert an object into only one contact opening, and there is no contact with electricity. Tamper- resistant receptacles are an important next step to making the home a safer place for children.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Ed911 (03-14-2012)
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 10:51 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
