-   -   kitchen gfci (http://www.diychatroom.com/f18/kitchen-gfci-68842/)
jce 04-11-2010 08:15 PM
kitchen gfci
I'm redoing our kitchen & from what I can read, gfci required within 6' of sink & ALSO 2 20amp required for counter ?
Is the 2-20amp for counter required for remodel or just new construction ?
thanks
J
Scuba_Dave 04-11-2010 08:19 PM
Where are you located ?
US requires (2) 20a counter circuits & GFCI protection
brric 04-11-2010 08:23 PM
All kitchen countertop receps must be GFCI protected.
jce 04-11-2010 08:25 PM
I am in Pennsylvania , sorry !
If it's a remodel , does "new" code still apply ?
Just curious , if not near water , why the gfci requirement ?
Scuba_Dave 04-11-2010 08:28 PM
Yes, once you remodel you need to meet current codes
Kitchen counters are considered wet prep/possible wet areas, so all must be GFCI
Not sure of exact wording
spark plug 04-11-2010 08:42 PM
"Existing" is OK the way it is (No Brainer?:laughing:) Once, any alteration is done, --except for replacing the receptacle itself-- it must be brought up to code. Meaning any Year of the NEC your AHJ (Local Code enforcement agency) is up to!
andrew79 04-11-2010 08:51 PM
thanks
J
anytime your redoing wiring it falls under the present code standards. If your just replacing a device(plug, switch) then that doesn't count. I'm not qualified to answer this as i'm not familiar enough with the NEC but the number of plugs needed is probably dependant on total work surface....if there's an island....penisula. Some plugs may be exempt from having a GFCI after a certain distance from the sink or for special cases such as the plug is inacessable.
Scuba_Dave 04-11-2010 08:53 PM
http://i767.photobucket.com/albums/x.../21052-web.jpg
plummen 04-11-2010 09:07 PM
dont forget to use the tamper resistant gfis and plugs if its being inspected
andrew79 04-11-2010 09:11 PM
a question for my own curiosity. Do you have to alternate circuits on the counter top and is there a max your allowed to have on each gfci circuit?
Scuba_Dave 04-11-2010 09:28 PM
I have not read any code (in the US) requiring you to alternate the outlets on a different circuit
It is a good idea, I will alternate circuits/outlets in my kitchen & will have 4 20a circuits for the counter due to it being open to the sunroom
There isn't any Max capacity as far as outlets, but it must be outlets only
DW & disposal can't be on the circuit
Refridge can but I ran a dedicated 15a circuit using 12g wire for my fridge
MW/combo fan/hood require a dedicated circuit
A plug in hood also requires a dedicated circuit
But a MW (over stove) alone apparently does not
Kitchen can be a pain to wire
57_Hemi 07-28-2010 07:11 AM
***BRAND SPANKING NEW MEMBER HERE***
My apologies for bringing this older thread up but I have a question?....
Im in the process of remodeling an older home wife and I just purchased approx 1 year ago. Built in the mid 1940s (Toronto, Ontario, Canada). I realize kitchen receptacles must now be wired with 12 guage AND gfci protected. My first plug is approx 3.5ft away from our double sink and has a 20amp GFCI receptacle with dedicated 12/2 straight to the electrical panel. However, Im still a bit confused regarding the other 2 counter plugs. They are both on the other side of the counter (approx 4.5ft & 6ft away from sink).
Can I ....#1
Run a 12/2 to one receptacle with a GFCI then branch of the load of the receptacle to the last receptacle ?
OR....#2
Must I have 2 seperate 12/2 dedicated runs (one to each receptacle) and install 2 seperate 20ap GFCI's ?
(Im veering towards option #1, more practical I would think)
It's been a while for me and back then a simple 14/3 looped over to the next plug on a double 15amp (dont forget to cut the bridges...LOL) was acceptable but I realize that thee codes are changing everyday and want to make sure things are done correctly acording to current regulations.
Any help would be awesome..............THANKS
D
TORONTO
"I dont have a problem tackling any job.....I just need the money to start it"......(d.a)
