Kitchen GFCI With 12/3 Feed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 06:17 AM   #16
Electrician
Rewards Points: 800
Any outlet within 1.5M of the sink needs to be GFI and according the CEC in your kitchen you either need a 15A split plug or you can use a single circuit with a 20A tslot. The CEC also says that your overcurrent protection can not be set higher then what the plug is rated for(So no 15A plug on a 20A circuit). Since they don't make a 15A GFI that you can split you are forced to go with a 20A cicruit and since your overcurrent can't be higher then your plug rateing you then have to use a 20A t-slot plug.
If you are further then 1.5M from the sink you are allowed to run 14/3 to a plug and split it.
Hope that makes sense.
darren is offline   Reply With Quote
Old 10-23-2010, 07:49 AM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Originally Posted by jlhaslip View Post
Don't you split the receptacles so that the top and bottom are on different circuits?
GFCI receptacles can not be split to allow 2 different circuits. There is a single set of line terminals and a single set of load terminals. And no brass tabs.
Coastal South Carolina
Old 10-23-2010, 10:15 AM   #18
jlhaslip's Avatar
Rewards Points: 2,728
Thanks. I'll be in the wood working shop if you need me...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
GFCI plugs in kitchen DeterminedMom Electrical 10 04-23-2009 10:42 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
