Kitchen Floor Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 09:34 PM   #1
Limited Experience
I get to replace my kitchen floor this summer and and am making some plans.
More and more people want power for their laptops when sitting at the kitchen table. Which means stringing an extension cord across the floor as a trip hazard.
I'm thinking a flush mounted floor outlet under the area where the table goes would be nice. But I suspect the rules for kitchens might not allow this.
Any comments?
raleighthings is offline   Reply With Quote
Old 02-05-2012, 11:25 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
As long as you have the right box to mount it in and its protected by some sort of gfi i wouldnt see a problem with it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 11:35 PM   #3
Rewards Points: 13,450
Sorry, not a great idea. Reasons being a floor outlet is far more expencive, it's a trip hazard, at some point there will be dirt, dust, water getting into it. Just stop by HD or Lowes and see what a floor outlet and cover cost.
Just add an extra wall outlet near the table. Total cost about $5.00 or less.
Old 02-06-2012, 01:34 AM   #4
Julius793's Avatar
I think it's a good idea if you know where your going to place your kitchen table. I would get one with a cover of course, so it can be closed when not in use. In addition I disagree with post number 2 about it must be a gfi!
So to plummen can you please provide an article #? or was it just a suggestion?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-06-2012, 02:09 AM   #5
plummen's Avatar
Just covering myself about it being in the kitchen area is all,because Im sure if I dont mention it somebody else will hang from the nearest tree over it.
Old 02-06-2012, 06:53 AM   #6
Julius793's Avatar
Just skimming through the nec I figured I would mention that this outlet will not exempt you from the 6/12' rule unless it's within 18" of the wall.
The Following User Says Thank You to Julius793 For This Useful Post:
plummen (02-06-2012)
Old 02-06-2012, 07:09 AM   #7
Licensed electrician
Rewards Points: 1,478
I think I would be concerned with spills and liquids from cleaning the floor. I know the code addresses face up receptacles in countertops and am only applying the same consideration to the floor mount.
This might also limit the layout of the room.
When I use the laptop in the kitchen a wall receptacle is never that far away.
Old 02-06-2012, 07:16 AM   #8
Limited Experience
There is an outlet near the table. It is a PITA.
I know they are not "cheap". But as to a trip hazard, why unless it is a poor install. Given that I need to take my kitchen floor down to the joists, sister in new joists to remove my bounce, add 1"+ of plywood, then tile, this outlet could cost $300 and it woul get lost in the budget.
And given the size of my kitchen there's a very small area where it would go and it would be under any table in the room.
Old 02-06-2012, 07:23 AM   #9
Julius793's Avatar
Yes consideration should be taken however on the counter it's not allowed here it is.
Old 02-06-2012, 07:27 AM   #10
joed's Avatar
Rewards Points: 12,376
Consider the location before you install . Do you really want it UNDER the table when plugging and unplugging the laptop.
Old 02-06-2012, 01:32 PM   #11
Limited Experience
Isn't needed every day. But when needed laptops tend to be there for hours. I'll trade 30 seconds to plug in vs. hours of people walking around and over extension cords.
Old 02-06-2012, 01:34 PM   #12
Limited Experience
Good point. I'll look into covered unit with a water seal so mopping the floor isn't am issue.
Old 02-06-2012, 01:43 PM   #13
Rewards Points: 252
Get one of those spring loaded retractable reels that are made for a shop and hang it from the ceiling. Whenever you need it just pull it down, it could be a design feature!
shazapple is offline   Reply With Quote
Old 02-06-2012, 03:29 PM   #14
Limited Experience
I almost made a comment myself about this as a choice. But I know just how far the design committee would let this plan proceed.
Old 02-06-2012, 04:59 PM   #15
Rewards Points: 83
I would prefer the outlet to be near one corner of the table in the ceiling, but then I can easily reach an 8' ceiling standing flat footed on the floor.
davido30093 is offline   Reply With Quote
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 10:51 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
